Question about Amana ARB1905C Bottom Freezer Refrigerator
Start relay keep burning start relay
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check voltage if good change compressor
Posted on Apr 01, 2009
2010 ford f150 keeps blowing the starter relay where do i look for a short?
make sure it is not grounding out at the starter itself ,also ck the alterantor wire same deal then goes to batt.
Jan 19, 2015 | 2010 Ford F-150
How To bypass the Fuel Pump Relay
Don't bypass the fuel pump relay . power to the relay comes from the ignition switch on start cycle .when the engine is running the oil pressure switch takes over the circuit .so if you crash and the engine .stops so does the pump . If the fuel line brakes a bypassed pump will keep pumping spraying fuel and you could burn.
May 05, 2014 | 1997 Nissan Maxima
How do you replace an ignition switch in a Lincoln Navigator?
Don't believe it would be the ignition switch. It sounds like the starter relay may be stuck in the on position. Find the starter relay and pull it out. One terminal would be hot at all times-use a test light grounded to engine block and probe the relay terminals. Should only have one terminal showing power. Now have someone hold the key in start position. Now you should have two terminals showing power, and when key is released to the run position, the second hot terminal should stop showing power.
If it works like this, try a new relay, or a known good one. If second terminal still shows power without key being in start (cranking) position, then it may be the ignition switch or the wiring and connections between the switch and the starter relay.
You will keep burning starters out till fixed. Starters that are run more than a few seconds at a time will get too hot and burn out.
Jun 26, 2013 | Lincoln Cars & Trucks
Starter switch burning out
I would check the relay first and make sure there isn't a corrosion build up there. An amp meter would help to troubleshoot this problem, looking for large amperage draws to the switch.
May 29, 2012 | Polaris ATV
My 2003 lincoln navigator wont start and the error message in the dash board keep saying..PRNDL ERROR PARK ASST..does anyone knows what that means?
check the relay #303 if its burned or damaged and you can buy it at an auto parts if that relay is not the problem check the rest of the relay just to make sure they are working properly hope that this can help with your problems
May 13, 2012 | 2008 Lincoln Navigator L
Headlights go on and off during a trip
Go to Autozone.com and register your vehicle for FREE and then you can get Fusebox diagrams and even chassis wiring layouts. I suspect you have a bad Headlamp Relay. Just look at the Fusebox layout and replace that relay to start with.
Jan 25, 2012 | Cars & Trucks
Keeps blowing the starter fues
Hi, if you're talking about the 10 amp fuse #12, pull out the starter relay and put in a fresh fuse. Try to start the truck and then check the fuse. If the fuse is OK, get a new starter relay. If the fuse burned without the relay, there is a short between the ignition switch and the starter relay. If you have a manual transmission, you can further isolate the short by pulling the connector off the switch above the clutch pedal. Put another fuse in and try again. If the fuse burns, the short is between the ignition switch and the clutch switch. If not, it's between the clutch switch and the starter relay. Please let me know if you have questions, and thanks for using FixYa.
Jun 19, 2011 | 1992 Isuzu Pickup
I have a Kenmore Coldspot Model 106.7629461 Here's the problem: When the unit needs to run to keep the freezer/refrig cold, it does so for about 10-15 seconds. Then it shuts off for about 2-3 minutes. ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Kenmore Refrigerators
1998 chevolet blazer that burning fuel pump relay
Recommend change out juncktion block that relay fits in,will have internally burnt contacts that you cannot repair.
Jun 18, 2009 | 1998 Chevrolet Blazer
Amana ARB1905C Bottom Freezer Refrigerator Logo
79 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
