Question about Breville BES860XL
Broken breville grinder
Grinder makes uneven random grinds. Grind selector broken
  • rob l Sep 01, 2013
    How do I open it up to get at the internals?
4 Suggested Answers
SOURCE: Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Posted on Jan 07, 2009
mc1bean
  • 3053 Answers
SOURCE: makes funny noise when I try to grind coffee and
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Posted on Jun 13, 2011
  • 37 Answers
SOURCE: grinder jam on breville barista express
Only way to know for sure is by taking it completely apart and expose all the internal parts
Popping is not a good sign If it is electrical arcing you are playing with fire
or electrocution
If you are mechanically inclined they are not that hard to take apart as long as they have no security screws on it and you have to remember you might be voiding your warranty
But it is fun taking things apart No?
Posted on Feb 06, 2012
Grind time is short, puck is wet and sloppy, espresso weak
Sounds like you might have more than one problem.
From page 12 of the manual... NOTE THE LAST LINE.
"8. ADJUSTING THE GRINDER
• Open the lid of the bean container.
• While the grinder is running turn the grind selector switch to
the desired position (Fig. 6).
-The smaller the dots, the finer the grind.
-The bigger the dots, the coarser the grind.
Important:
The grinding grade can only be adjusted while
the grinder is actually grinding."
Sep 08, 2014 | Jura Capresso Impressa E8 Espresso/Coffee...
I have a Breville BES860XL and the grinder is not working. If i overide the interlock, It will spin, but does not have enough power to grind beans
It seems there's a fault in the grinder gearing in this particular model.There's no solution but to take it to Breville repair...
I have the same problem and so does a friend of mine. The grinder will spin without beans in the hopper but as soon as beans are introduced the grinder makes a loud noise. Like the gears are slipping and there's not enough power to grind.
Jun 10, 2011 | Breville BES860XL
Where does the water go
This is a COFFEE GRINDER. Designed to grind coffee beans to into a powder . This powder is then put in a coffee machine or a coffee peculator to brew coffee. DO NOT put water into the coffee grinder !
Dec 19, 2010 | Breville Conical Burr Coffee Grinder -...
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
With the dial turned to "Turkish" I still get a very course grind. How to adjust/fix?
On the adjusting knob there are 2 set screws (outside of the center) and an adjustment screw (the one in the middle). First make sure the LARGE screws on the side of the SELECTOR plate are tight. Start with the selector on Turkish, with the grinder OFF loosen the set screws about one full turn each. Leaving the selector on Turkish turn the grinder on and gradually VERY SLOWLY turn the center screw clockwise. Eventually you will hear the burrs inside touching. After they touch back of the center screw about 1/8 of a turn. Tighten the SET SCREWS tight as they may allow the grinder to go out of adjustment if not tight. Test the grind with very little coffee and throw those grounds out. Then grind and brew! If these grinders are adjusted too fine you may have problems with the grinds not falling and may back up.
Apr 26, 2010 | Grindmaster 810 Electric Burr Grinder
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
Breville Die Cast 800ESXL Espresso Machine: Problem... Watery espresso. My machine worked great for a year, then all the sudden, the espresso is watery and the basket where the grinds are is full of water...
Personnaly, when I use the big filter, the grinds are dry after the extraction, but for the small filter, it's all soggy. If you look at the documentation, ( http://kitchen.manualsonline.com/manuals/mfg/breville/breville_coffeemaker_product_list.html) they say wet coffee grind after extraction is normal.
But did you change the coffee brand ? Or the grinding level ? How do you grind your coffee ? I had big troubbles once with a commercial grinder at my grocery store, it's when I decided to buy my own Breville grinder.
Good luck,
JF
Oct 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
Severe clogging
Try using long grain white rice works better than minute rise, if that does not help, then the burrs need to be replaced on grinder.
May 12, 2009 | Breville Conical Burr Coffee Grinder -...
Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Dec 21, 2008 | KitchenAid A-9 Electric Burr Grinder
Breville cafe roma
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Breville BES860XL Logo
53 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
