Question about HP PSC 2210 All-In-One InkJet Printer
Installed ink cartridge, prints from printer, but not from comput
Installed the ink cartridge this am. and as quoted prints from printer, but not from the computer. Had this problem last time I installed and took me two days to figure out. I had two computers on the program and I deleted the other and it seemed to work. I can't remember how I did this and I do need some assistance. Would appreciate it very much
  • Anonymous Jan 05, 2009
    my scaner says can not download description
    President:
  • 2,692 Answers
To delete a printer go the the  controll panel printers and highlight it and delete it. That should not be necessary. . Go to you support page and download the drivers for the version of windows that you have. Delete  the present printer  off of  your computer (software) Reinstall the new downloaded software driver. Now hook up and turn on the printer.
http://h10025.www1.hp.com/ewfrf/wc/product?product=79499&lc=en&cc=us&dlc=en&submit.y=5&submit.x=5〈=en&cc=us
Posted on Jan 07, 2009
Can Dell A960 ink cartridges be refilled and re-used or not?
A lot of inkjet printer manufacturers make you purchase their ink cartridges by installing a chip in the cartridges so when the cartridge is empty it cannot be reused by filling the cartridge.
Jan 28, 2013 | Dell A960 All-In-One InkJet Printer
I just want to print - computer says it is "off-line'. Print says "scan, copy, etc." but not 'print'. What do I do?
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .Use the test print to calbrate the SCANNER.
Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 02, 2011 | HP C4680 All-In-One Inkjet Printer
I installed the drivers for a canon pixma mp210 and it wont scan. it keeps saying " E 1 6"
"E 1 6" error code means Ink has run out.
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Jun 11, 2011 | Canon PIXMA MP210 InkJet Printer
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
Installed new black ink cartridge, message keeps coming up that I need a new cartridge. I have cleaned, restarted my computer, everything I can think of. It still will not print. The message says to...
Even new cartridges can prove to be faulty; even more so ones that have be refilled. If you have exhausted the options in the print software (i.e. Test Print, Print Alignment, Head Cleaning, etc.) and the reseating of the cartridge a few times, then depending on your will for either try:
1. Go to the store and replace the cartridge telling them you think its faulty.
2. Firstly, Unplug the Printers connecting cable (USB, DB25, etc.).Then uninstall both the Printing software and Printer drivers (usually the same package) under "Add Remove Programs" (Windows OS). Restart the computer, then reinstall the Printer software (following the prompts on exactly when to reconnect the printer to the computer, *Important*), and then restart again.
Jan 30, 2011 | Lexmark Z2300 InkJet Printer
I replaced the color ink cartridge. Now there is an "E" flashing alternately with a "5". The alarm light is on steadily, and the black ink and color ink lights are flashing. How do I...
E5 is a Cartridge cannot be recognized error.
Reinstalling the cartridge could clear the alarm.
If this does not work,
Removed both ink cartridges.
Turn off printer and unplug fron electrical outlet.
Wait at least 5 minutes.
This will let the printer reset itself.
Plug printer back in and turn on.
Printer will cycle and an E5 will appear.
Installed back ink cartridges.
Jan 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I HAVE JUST REFILLED MY LEXMARK X2550 PRINTER COLOR CARTRIDGE NUMBER 35, BUT A MASSEGE ON MY PC SAYS: "Invalid Cartridge". How do l get it to be recognised so that l can use it?
hello
35 is color ink cartridge .. high yield,
A new color print cartridge needs to be installed.
If available, click the Continue button on your computer screen to print using the
black (or photo) print cartridge. (The Continue button is available only at the
beginning of a print job.)
Note: A variable amount of ink remains in the color print cartridge.
Follow these steps to replace the color print cartridge in your printer:
1 Cancel the print job if not already canceled.
2 Replace the color print cartridge with a new cartridge. For more information,
see "Removing a used print cartridge" on page 35 and "Installing print
cartridges" on page 35.
3 Print again.
To order supplies, click Order Ink on your computer screen. You can also see
"Ordering paper and other supplies" on page 40 in this guide.
Troubleshooting 54
manual = http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
Installing print cartridges
1 If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
1 2
Warning-Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the
Maintaining the printer
35
list of ink cartridge part numbers
http://www.lexmark.ca/lexmark/product/home/455/0,6970,204812589_653399443_1037657543_en,00.html?tabId=7
Dec 23, 2010 | Office Equipment & Supplies
HP DeskJet 5150 , ink problem :S
replace the cariridge because when you refill the sensor gets triggered and the cartride is unusable.
May 08, 2009 | HP DeskJet 5150 InkJet Printer
Bought today a hP7200 All-inOne Series. Set up and received the following: Error message "Incorrect Ink Cartridge: The following ink cartridges cannot be used after device initializaed and must be...
hi friend
try remove your printer cardige & rinstall it if u have not remove your printer cardige nosel raper so remove tape of the nosel try to install & print
Apr 13, 2008 | Office Equipment & Supplies
HP PSC 2210 All-In-One InkJet Printer Logo
27 people viewed this question
Ben Johnson
