Question about Kenmore Washing Machines
Washer shutters when the water is shut off after filling.
Kenmore Model # 110.26832691
Could it be the water inlet valve?
  • 15,935 Answers
Yes. Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
Kenmore washer frontloader model 417.41122410 code E11
An E11 error indicates a problem with the incoming water. The error will occur if the tub doesn't fill normally in about 8 minutes. This could be related to closed shut-off valves, failing anti-flood hoses, or debris in filters in the hoses or at the inlet valve on the washer. It could also come from a fault with the sensor that detects the weight of the washer tub, a problem with the reed switch that tracks water flow into the washer, the air tube that goes to the reed switch or a failure of the inlet valve. It can even indicate that the end of the drain hose is below the water level in the washer and is siphoning water out as the tub fills.
If no water or a trickle of water is reaching the tub, first make sure that the shut-off valves are open. Next close the valves and disconnect the hoses. Place the hoses into a bucket and check the water flow by opening the shut-off valves. Shut off the valves. Clean the filters, including those in the inlet of the washer. Reconnect the hoses or replace them with new ones if there was low flow. (Check the flow at the shut-off valves themselves with a similar bucket under the valve opening, if you can.) If these steps don't work, you need to replace the inlet valve assembly. It failed in the closed position.
If water is filling the tub normally and flowing out the drain, check the drain hose position. If the tub is filling and is held in the tub, then the washer isn't correctly measuring the water flow. Check the reed switch and that tubing by blowing into the tube. Replace a faulty switch and remove any blockages from the tubing. Check the wiring harness to ensure that the message got to the control board.
See http://www.searspartsdirect.com/model-number/41741122310/0582/0153200.html for parts diagrams and price lists. You need the control panel diagram.
I hope this helps.
Aug 15, 2017 | Kenmore Washing Machines
KENMORE DISHWASHER, WATER CONTINUES TO FILL AFTER WASHER IS SHUT OFF.
You're correct you have a faulty water inlet valve. At the end of the wash cycle the solenoid in the valve is not closing properly to not allow water to re-enter the tub. For further assistance with this repai
Jan 21, 2014 | Computers & Internet
Kenmore elite washer little amount of water fills washer
If I am understanding the question, you have low water pressure/volumn when washer is filling? If so, unplug washer. Shut off water at valves. Remove water lines from rear water inlets on washer. Clean debris from screen filters in water inlets or in supply lines. Flush supply lines into bucket. Reconnect water, power, and test.
Jul 22, 2013 | Home
Water not filling up kenmore washer model number11024642300
The most common thing that causes the washer not to fill up with water is the water inlet valve. If this valve has power to it when it's supposed to be filling with water, and you have adequate water supply to the washer, then the washer should be filling with water. The part number for the replacement valve is 285805.
Mar 22, 2012 | Kenmore Washing Machines
The water will not shut off completly it keeps trickeling in and will fill the drum after a week.
The reason that is happening is because the spring inside of the water inlet valve that is suppose to close it is weak and its not fully closing the valve so water seeps through it into the drum of the washer. To repair that the water inlet valve will need to be replaced.
If ya reply with the model number i will give ya the part number for that valve and instructions of how to replace it.
The model number can be found on a label inside of the door on the rim
GENE
Oct 10, 2011 | Kenmore 44042 Front Load Washer
Washer won't fill with cold water
hi..
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open..
thank u
rate me..
Aug 15, 2009 | Kenmore Washing Machines
Kenmore series 80 washing machine overfills, it will not start washing, it just fills and runs over
Hi, The first part to check is the inlet valve. If you shut the washer off, will the water stop? If the water continues when the power is off to the washer, change the inlet/mixer valve.
If the water stops filling when the power to thee washer is shut off, the water level switch needs checked.
Please let em know if either of these help so I can assist you further.
Vic
Jun 20, 2009 | Washing Machines
Fills with water when not in use.
Hi, If the washer fills up when off, you will need to change the inlet mixer valve. Do you have to shut the water source valve off to keep it from filling up?
Please let me know so I can assist you further.
Thanks
Vic
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
How to access filter for kenmore elite front load washer
To access the pump drain filter, follow the instructions in the link provided:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
It is recommended by the manufacturer that if the pump still does not operate correctly after cleaning, to replace it. It does not take much to damage the motor and impeller of these small drain pumps.
The water fill problem is usually caused by a water inlet valve that is not shutting off properly. To access the fill valve solenoids follow these steps:
1. Unplug the washer.
2. Remove the top panel of the washer by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off.
3. The inlet valve is located at the left rear of the washer (as viewed from the front). This is where the fill hoses attach.
4. A resistance reading of the valve solenoids should be between 750 and 850 ohms.
If you live in an area that has hard water, or if you use well water it is common for sediment and/or deposits to accumulate in the water inlet valve and cause problems with either filling or shutting off. you can attempt to remove the valve and clean it to see if this will correct the problem. Use white distilled vinegar to submerge the plastic portion of the valve in. DO NOT submerge the electrical contacts. Sometimes soaking in vinegar will dissolve and remove hard water deposits and sediment. If you wish to simply replace the valve, follow these steps:
1. Leave washer unplugged and remove electric connections to inlet valve.
2. Shut off water supply and remove fill hoses from the back of the washer.
3. Remove the dispenser hose from the inlet valve and remove mounting screw(s).
4. Install replacement valve in the reverse order of the steps provided.
Replacement parts can be purchased on line at searspartsdirect.com, repairclinic.com, or appliancepartspros.com. All three sites have great service and offer competitive pricing. I would recommend checking with all three sites for the best price. Use your model number to initiate your search.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
22 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
