Question about Husqvarna 125bt 25.4cc 2-stroke Gas Backpk Blower Wnty
Why is my Husqvarna 125bt Backpk Blower beeping?
  • 430 Answers
There are no warning buzzers or electronics on the unit. You need to look for something that may be making the noise... A loose motor mount behind the impeller, something stuck inside the shroud that the impeller blades are scraping, a loose cylinder or spark plug causing a compression leak are somethings that I can think of that may cause a beeping or squeeking sound. Maybe a partially clogged exhaust.
Posted on Nov 12, 2012
slohry
  • 87 Answers
SOURCE: hard starting and when warms up rpm's drop
Remove the muffler and inspect the piston, rings and cylinder for vertical scoring. If so You may need a top end rebuild.
Posted on Apr 10, 2009
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
  • 122 Answers
SOURCE: my husqvarna 125bt blower chokes out when given
Most likely the high speed needle on the carburetor need to be turned in(clockwise) just a little . But it could be other things also.
Posted on Feb 02, 2011
gar6310
  • 24 Answers
SOURCE: i have a Husqvarna 125BT blower. It runs fine but
GAP is the opening between terminals at the end of the spark plug ( on the threaded side of the spark plug) but spark plugs should come with the right gap from factory, as for your problem with to restart your blower it is ok just need to let cool down for 15 min or more.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Posted on Feb 03, 2011
gar6310
  • 24 Answers
SOURCE: I have a 125bt Husqvarna power blower, I need to
sears parts and service with model #
Blower does not open up all the way
Clean carburetor and spark
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Apr 04, 2014 | Husqvarna 125bt 25.4cc 2-stroke Gas Backpk...
Where are adjustment screws on 125bt
They are on the side of the carb however there is a special tool required to adjust them , they have no slot in the top to fit a screw driver, the tool is part no, 530035560
Jul 06, 2012 | Husqvarna 125bt 25.4cc 2-stroke Gas Backpk...
My husqvarna 125bt blower chokes out when given full throttle
Jan 30, 2011 | Husqvarna Backpack Blower 25cc, 140 Mph,...
What s fuel mixture for husqvarna fuel mixture 125 blower???
Mate, I run mineona 20:1 mix.
they tend to only used a stronger mix (i.e.50:1) for the first 20 hours of operation. Hope that helps.
Jan 07, 2011 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Broken pull rope on 125BT Backpack Blower
Most small engine shops and big box stores like home depot sell generic replacement starter rope. If you want the exact part from Husqvarna, there are 2 engine variations for the 125BT. The rope for the AC57 enigne is part# 531009567, the rope for the AC55 engine is part#531009653.
Jan 04, 2011 | Husqvarna Forest & Garden 125bt Backpack...
My Husqvarna 125BT leaf blower will not make full power anymore. The past few weeks I noticed a strange sound best described as as a rattle similar to a loose baffle. Starts and runs fine but only makes...
Try pulling the muffler off and checking for blockage in the exhaust port, expecially the small hole above the main exhaust port. This is the same thing that my 125bt was doing this season and after cleaning out the carb with no improvement, I found some carbon build up in the exhaust port. The small hole above the port was completely blocked. After cleaning up all of the carbon buildup, it ran back to full power again.
Oct 30, 2010 | Husqvarna Backpack Blower 25cc, 140 Mph,...
I have a Husqvarna 125BT blower. It runs fine but
May 15, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Husqvarna 125bt backpack leaf blower. I put
Oct 21, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Hard starting and when warms up rpm's drop
Dec 21, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Husqvarna 125bt 25.4cc 2-stroke Gas Backpk Blower Wnty Logo
98 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
