Question about Dell 1355cnw AllInOne Led Printer
My Dell 1355cn multi function printer tells me there is a paper jam in the back. I can't find it anywhere. Just before this it told me to clean the CTD sensor I did and then this came up, HELP!!
How do I find a paper jam in the back of my 1355cn printer when I can't see it anywhere?
    Top Expert:
  • Dell Master
  • 1,144 Answers
See User Manual, pages 448, 459-474:
http://content.etilize.com/User-Manual/1019370073.pdf
Posted on Jan 06, 2015
SOURCE: Dell 924 Inkjet Printer False Paper Jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect).
Posted on Apr 12, 2008
devdeep545
  • 137 Answers
SOURCE: Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Posted on Aug 09, 2009
Peoples book
  • 9 Answers
SOURCE: Paper jammed (Dell lase Printer 1720dn
Open the back cover and look for paper wrapped around a roller back there. That is the most common cause of the issues with this machine. The other thing you can try is to push down on the little flaps where the paper comes out of the printer. These get stuck and need cleaning/replacement all the time in the later life of these models (1720's).
Posted on Aug 22, 2009
  • 34 Answers
SOURCE: We have a Dell 5110cn and we keep getting a
Follow the steps under "Cleaning the Automatic Density Control (CTD) Sensor" heading at the following link. If the problem persists after cleaning the sensor may be faulty and you will need to contact Dell for warranty support.
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Posted on Jan 21, 2010
doron_c21
  • 387 Answers
SOURCE: I have a Dell 3010 that has error msg paper jam
you need to check the fuser, sometimes a small piece of papaer or a label stick on he fuser in order to do this you need to open the back and top cover. or take the printer to service
Posted on Aug 21, 2010
Testimonial: "when I finally figured out where the fuser was,there was paper rolled around roller. I carefully unrolled it with its feeder wheel. Its OK now. TU "
Dell 1355cn error 007-371. what is it and how to fix it.
the error is related to the PHD , photoconductor unit is a component of a laser printer that includes a photosensitive print drum. Digitized data is sent via an electrostatic charge to the photoconductor or photosensitive drum, also called the PC kit, which then distributes the ink to the paper. try removing it and ensure their is no packaging stuck around it if it's new, it could also be faulty if you can try another from another Dell 1355CN, if it the error occurs again i would suspect their is a fault with the printer and recommend returning the unit
Nov 29, 2016 | Dell 1355CN Multifunction Printer - Color...
Paper tray jam
I would first go to the manufactures web site and ask for support. In the mean time, I would open up the paper tray and inspect where the paper feeds into the rollers. If there is another access point, where the paper comes out, inspect that area as well looking for paper or fragments. Sometimes if you can turn the print rollers by hand a paper jam will reveal itself
Jan 20, 2015 | Dell 3765dnf Colour Multi-function Laser...
Keeps telling there is a paper jam
This particular 'paper jam' error on the Dell 3110/3115/3130 can often be caused by the paper not being picked up from the paper tray. The printer 'expects' to 'see' the paper pass various sensors during it's path through the printer. Each one has a 'time window'. If the paper is not seen to pass sensors at the correct timings, a paper jam is assumed.
Now - to cure the problem.
Just cleaning the (3 identical) pickup/separation/feed rollers in the paper tray area could be enough (they get a build-up of paper dust - can affect their effectiveness).
One of these rollers wears much quicker than the rest, and gets a pronounced flatspot. Replacement rollers are available via 'that' well known internet auction site.
Feb 05, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
Clean CTD on Dell 1355CN LED Printer
Neither the image of the printer [I'm looking for the Dell 1355cn] nor the instructions to get to the CTD sensor are correct. So no help at all.
Apr 18, 2012 | Dell 5110cn Laser Printer
Carrier Jam? What? I can't see anything wrong, I've cleaned it all, what do I do?
See if there is a door on the back of the printer. I have found paper jammed back there when I couldn't see it anywhere else.
Jan 27, 2011 | Dell V305w All-In-One R840635AU InkJet...
I have a Brother MFC-685CW printer. I have unjammed a paper successfully. Yet the Printer is still telling me there is a paper jammed. How can I delete this message?
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the Multi Function Printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
May 24, 2010 | Brother Office Equipment & Supplies
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Dec 08, 2008 | Brother Multi-Function Center MFC-240C...
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Dell 1355cnw AllInOne Led Printer Logo
158 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
