Question about Leviton Decora 30-15-10-5 Preset Minute Electronic Timer White #612-6230M-W
Are the switches bad .? If so this would be strange as both switches are at the same time .thanks
  • Leviton Master
  • 5,245 Answers
Is this new installation?
Sounds like timer is wired wrong.
Or you are replacing 3-way switch with the single-pole timer.
Copy following link for step-by-step wiring
http://waterheatertimer.org/How-to-wire-timers.html
Posted on Nov 10, 2012
No lights when switch is in first position
Do tail lights come on in that position? If yes-- the switch should be OK. This may sound strange but I have see both bulbs bad at the same time in some cases. Did you try at least 1 new bulb.
Mar 04, 2015 | 2008 Toyota Tacoma
Why both low beam headlights stopped working at same time?
my quess is the headlight dimmer switch is bad,cant be headlight switch cause lights come on.strange things happen on car electrics still could be bulbs burned out,it does happen.buy one put it in see if light comes on,if not dimmerswitch is bad
Jan 03, 2015 | Cars & Trucks
99 voyager starting problems
Your ignition switch is going bad. The strange noise is the starter remaining engaged and locked to the flywheel. Your best bet is to have the starter tested at your local auto parts store, to deduce that it is not, in fact, your starter.
Nov 05, 2013 | 1999 Plymouth Voyager
Operation of water pump on km500mae hoshizaki
I have found that if the pump runs in the wash cycle but not in the ice making postion, the switch is bad. strange but I have had this happen multiple times.
Oct 08, 2013 | Hoshizaki Freezers
My 1080p Mitsubishi television suddenly stared to switch itself off and then a red light would flash for a minute. When I turn it back on I am geeting sound for a few minutes and then it switches itself...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 4000 hrs,1-3 yrs it could be time to replace the lamp.The lamp you need is 915b403001 .Have a blessed one!
Mar 29, 2010 | Mitsubishi WD-60735 Projection Television
Strange beep and keyboard skips or misses strokes
Hi
Go to security center then check for settings. hardware and software is not the issue,. only the settings!
Thanks!
Jun 06, 2009 | HP Pavilion zd8000 Notebook
I have a built-in GE microwave Model JTP85W0A1WW built in April 1999. It appears to work (fan turns on and digital readout counts down) but the turntable no longer turns and nothing is heated. Seems...
I had the exact same problem. There are two switches on the door. One is a safety lockout switch for the magnatron. The switch just wears out.
Jan 13, 2009 | Microwave Ovens
Ignition lock Cylindar to switch Connecting Rod Broke
YES, THE BEST PLACE FOR YOU TO BE CALLING RIGHT NOW IS THE LOCAL WRECKING YARDS! YEP! THERE GREAT FOR STRANGE PARTS THAT YOU'RE NOT GOING TO FIND NEW, MOST LIKELY. THEY ALSO KNOW WHAT OTHER CARS USED THAT TYPE SWITCH AND CAN REALLY SAVE YOU TIME AND MONEY! I'VE USED THEM, MANY TIMES AND HAVE NEVER HAD A BAD EXPERIENCE FROM ONE. JUST FOR KICKS, IS IT SOMETHING THAT CAN BE MADE. IF SO, YOU MIGHT TRY A MACHINE SHOP. LOTS OF TIME THEY CAN DO THINGS LIKE THAT. COUPLE OF IDEAS FOR YOU. HOPE THEY HELP. IF YOU NEED MORE HELP,REPLY TO:
ARCLIGHT1217
Sep 03, 2008 | 1993 Mercury Grand Marquis
Leviton Decora 30-15-10-5 Preset Minute Electronic Timer White #612-6230M-W Logo
43 people viewed this question
Top Leviton Hardware & Accessories Experts
Hippy_dd
Gene Haynes
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
