Question about Dryers
Frigidaire Stackable Dryer Model FSEC/FSGC748GF
SOURCE: when dryer turns sounds like something is banging around in there
replaced the barren
Posted on Aug 23, 2008
aborcass
  • 2651 Answers
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Posted on Dec 09, 2008
  • 686 Answers
SOURCE: irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Posted on Mar 02, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire stackable dryer wont turn on when i
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Posted on Jul 20, 2009
  • 512 Answers
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Posted on Sep 03, 2009
What's the resistance value in stackable dryer motor model fex831fs2?
There should be some for both the motor and the heater coil. Don't know how much don't have schematic. Hope this helps
May 18, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Irregular squeaking from stackable dryer
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Dryers Logo
Top Dryers Experts
