I wish to connect a HUMUX digital video recorder PVR-9300T and a TOSHIBA HDD & DVD video recorder RD-97DTKB to a SUMSUNG LCD TV LE32S73BD
Attatching other recording equipment
    Master:
  • 689 Answers
Get a tech to help you, There is to much info to try an (Explain) in writeing how to do it (Properly)
Posted on Nov 10, 2012
bhur
  • 85 Answers
SOURCE: toshiba rd-xs 24 dvd recorder
unlock your dvd using your remote
Posted on May 29, 2008
Nova_1
  • 196 Answers
SOURCE: Connecting PVR and satellite receiver
make sure you have a connection from one of your scart sockets (assuming you are using scart) on your sat to your pvr and then a connection (scart/hdmi?) to your tv from the pvr.
if you have a second scart or better still hdmi on your sat then plug that into tv
set top box scart output to tv
you do not say which tv model number you have so I dont know what input sockets you have but I will assume a couple of scart inputs and maybe a hdmi in (if hd version of tv) these days that would be considered a minimum amout of inputs so the setup suggestion above should be fine with that
Posted on Oct 14, 2008
SOURCE: TOSHIBA RDXV45KB
This is a disc read problem the discs recommended in the manual seem to be the only discs that will work on this machine.
I was getting the same error code everytime but the disc that i know does work is a Verbatim 16X DVD-R.
These discs work in all situations on my machine , dubbing and direct from TV.
Posted on Nov 29, 2008
SOURCE: Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Hey New firmware available for this "Timer issue" from Samsung and it works for me.
New firmware version - 080610.
Just ring Samsung and find out. They can advise nearest service cnter to do this.
Posted on Feb 13, 2009
SOURCE: Cannot record from my DirectTV DVR, HR20-700
most dvr units froim cable and satellite companies use a type of copy protection that does not allow you to copy programs to a disc. the cable company wont tell you this but they do and there isnt any way to work around it
Posted on Jul 18, 2009
I have my new TV connected to a Humax PVR-9300T Digital Video Recorder. I cannot access the Viera facility on the TV - can you help
try to read the instruction manual to assist you in connecting properly then follow the procedure on how to access the vierra facility
Sep 18, 2011 | Panasonic Televison & Video
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
TV Surround System
Sadly enough RadioShack is slowly becoming extinct, but they were the best! P{rovided both components have standard audio/video cables witht he red yellow and white tips you would have to find the audio and line OUT on the video recorder and plug them in to an AUDIO and LINE IN port on the subwoofer and speakers.
If the speakers have serious connections like guitar amp plugin type, then you would simply need a converter wire that is perhaps the standard audio cable on one end and the type you need on the other and THUS - RADIO SHACK!! Love that place. Otherwise if I'm way off, a stereo receiver can be a mediator for the two devices but similar cables will be needed.
Oct 19, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Can't get rid of subtitles on HDD recording. Must have accidentally put them on??? Also how can you delete HDD programmes?
I have a toshiba RD-88 DTKB dvd/hdd recorder, when i record on hdd subtitles are on when playback,tried everything to rectify ?
Feb 22, 2009 | Toshiba RD-XS34 DVD Player/HDD Recorder
DVD - Video Finalization rejection
1. The message can appear if the disc has already been finalised.
2. The disc may be faulty.
3. Try copying again from HDD to another disc. Performing a copy and finalise together by using 'DVD Video Creation' from the Edit menu can be more successful than doing each step separately.
4. When you transferred from your video camera, did you use firewire? If so, did you record at the maximum (default) bitrate of 14+ ? If so, you must copy (rate conversion) to the DVD at a maximum bitrate of 9.2, which is the maximum for the DVD playback standard.
Jan 01, 2009 | Toshiba RD-XS34 DVD Player/HDD Recorder
Jul 22, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Toshiba RD-KX50 HDMI freezes the recorder.
Press the standby button for about 10 seconds and will reset the HDD you may lose what you have on the HDD but will fix it.
May 07, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Hooking a vcr player to toshiba rd-xs35su
hi, connect it via a scart lead and switch to av channel.
Jan 13, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
