Question about Toshiba e-Studio 202L Copier
Toshiba estudio 202L failed to send e-mail when scanning
When I try to scan to e-mail, i get a "Failed to send e-mail" message. This has happened in the past and it always had to do with IP addresses.
SOURCE: Toshiba E350
Do you have the print option ? If not, you can configure everything, print jobs will show up on the cue, but they will just disappear into space. The print option looks like a USB key attached near where the network attaches to the copier.
Posted on Dec 12, 2007
  • 2072 Answers
SOURCE: Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
Posted on Jun 02, 2009
Copier_God
  • 57 Answers
SOURCE: cannot access shared folder where the toshiba
It sounds like you need to change the permissions of the share file, this would not be related to the copier as such as it just send the PDF/TIFF to the shared file.
Right click the file and check the permissions in the shares tab.
Posted on Oct 16, 2009
socalern
  • 48 Answers
SOURCE: I can not access my toshiba estudio 202L copier
Vista is notorious for not being "user friendly" printer drivers. Search the toshiba website for downloadable vista drivers. Try pcl 5 or pcl 6 drivers. also try the auto search feature of vista to search out the best driver. Good Luck
Posted on Oct 18, 2009
Testimonial: "Very good. I had resolved problem by the same answer before reply."
007tech
  • 95 Answers
SOURCE: How do you assign an ip address to a toshiba
1)press user functions
2)scroll down to initial setup and press enter
3)scroll down to network and press enter
4)scroll to TCP/IP and enter
5)scroll to address mode and enter
6)scroll to dynamic(automatic address) (or select static ip for manual entry) and enter
7)press cancel ONCE to return to network menu
8)scroll to "complete" and press enter (this will save changes and initialize network)
TO put in a manual IP address at step 6 above select static IP
7)scroll to IP address and enter
8)enter IP address and enter
9)scroll to subnet mask and enter
10)enter value and press enter
11)scroll to gateway and enter
12)enter value and press enter
13)press cancel once
14)scroll to "complete" and enter
exit out of everything
Posted on Jan 16, 2010
Scan not going through . Log gives 2C69 message. What does it mean?
Failed to connect to SMTP server. Make sure that the SMTP server is correctly working, or the SMTP server address has been set correctly
Dec 08, 2014 | Toshiba Estudio 2330c Copier
Why can't I send email from the estudio 202l?
Check the Admin settings from the web portal.
If you moved the machine from one router to a another for example, the machine may still have the old configuration, or make sure that the email account that the machine uses to send emails from is setup properly, i.e. correct username and password and SMTP for email provider. Mine was such a hassle to setup, and it was because we did a firmware upgrade on the router and had to factory reset the toshiba afterwards and connect via dynamic connection. It was troublesome since all the settings matched and were correct, but something in it, held the config some where. Another site said to flash the Toshibas firmware, but i never found a good download, so the reset was my best choice.
May 06, 2014 | Toshiba e-Studio 202L Copier
How do you connect a Toshiba estudio 202L to a windows XP professional version 2002 service pack 3?
Any device that is not made to work on windows 7-10 and higher (like any XP device) will not work.
Jul 28, 2017 | Toshiba e-Studio 202L Copier
I have a Toshiba estudio 202L copier. It has been working fine. When I turn it on, I hear it turning on like usual and see the light come on under the paper tray, there are no error messages, display...
try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Jun 14, 2011 | Toshiba e-Studio 202L Copier
Hi! I use Toshiba eStudio as photocopier & printer, but I didn't know why the message :"REMAINING 60 DAYS .." appear on LCD. How I return all as default setting. Tks!
on the toshiba machines you can activate a trial period for printing and scanning without the print/scan dongle this is what you are seeing
Mar 15, 2011 | Toshiba E-STUDIO 720 Copier
I replaced the drum and wiper blade and I need to clear the maintenance reminder on Toshiba eStudio 202L. I cant find the procedure in the service manual. Do you know which code will reset the...
switch off machine hold down 6 and print key switch on when the machine is on enter 2 and reset you counters switch off and wait 30 seconds and switch on again
Feb 11, 2011 | Toshiba e-Studio 202L Copier
I am using windows 7 and windows live mail with Cannon MP240. when scanning to email i get the message "failed to send email. check you mail program settings" I have updated printer drivers.
> check your mail program settings
Updating your printer's device-drivers will not be helpful.
Within Internet Explorer:
click File
point at Send
click Link by E-mail
This should open your "E-mail program".
Check the settings, e.g. "outgoing SMTP server".
Feb 05, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I can not access my toshiba estudio 202L copier from my vista pc but works fine from xp pc
Oct 16, 2009 | Toshiba e-Studio 202L Copier
Sending E-Mail Failed (0x80004005) - Fujitsu ScanSnap S510
You need to open Internet Explorer and add Thunderbird as your email program. Click Tools > Internet Options > Programs tab > E-mail: Select Mozilla Thunderbird from the drop down.
Jul 19, 2009 | Fujitsu ScanSnap Manager
Toshiba e-Studio 202L Copier Logo
139 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
