Question about Acer Aspire 5630-6288 Notebook
Wirless problem on my laptop
Well my wirles is bad because i live in wayne nj so i work in summit nj when iam in summit my wirless is not working at all when i com back in wayne my wirless is working good so i dont know where is the problem and how can i fix this problem pls hellp me how to fix thanks
  • kalpesh jain
    kalpesh jain May 11, 2010
    i not get you properly
My wireless on my m1210 not working
First chek the network status check the ip adreess is clear 0.0.0.0. and then try again if the network ip have some numbers 198.254.0.1 etc your wirles never gona work try it first
Feb 08, 2012 | Dell XPS M1210 Notebook
I can not see my bluetooth
Install bluetooth software and driver, + wirles driver and software, it is working with soft.
May 28, 2011 | Computers & Internet
Channel 2 (cbs) is fine. There is no sound. All other channels are fine. What is wrong and where can I take to have repaired. The TV is a 20" Norcent. I am in Summit,NJ, 07901
All the tv channels,work find and have sounds wright?Only channel 2 don't?Is not the tv,it channel 2 have broadcasting problems.U check around ur house the other tv channel 2 have sound?Tries go into the tv menu.Goto Audio Setting,go down to resetting the audio functions,now it going back to the factory setting,if it is the tv,that will help.
Nov 25, 2010 | Norcent Technologies TV2001 20 in. LCD...
Wirless conection dosnt work
it could be a driver issue with your wirless adapter what wirless router are you using
May 15, 2010 | Arris SURFboard SB4100 Modem
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
How to make a ADD-HOC to connect my Iphone Using usb modem
hi this is rajkumar
i can understand your problem.
the first thing is you have to share your internet connection to browse from your mobile. because you did everything.
if problem persists just post your problem again..
as soon as possible you problem will be solved.
thanks
have a nice day - bye
May 19, 2009 | 2wire (1000-400106-003)
Wirless router
The last thing you want to do is get rid of the password - operating an unsecured WiFi network can be very hazardous to your privacy & finances! You need to set the WEP password in the PC's. If you install the 3Com router software and use that to set things up, it will guide you through doing the job.
Also, it's better to use WPA encryption rather than WEP which is now regarded as insecure and little better than nothing at all. If you can get it working OK on WEP, it'd be easy enough to change it to WPA in the router & then change the setup on the PC's.
Unless you live in the back of beyond, this really is necessary I'm afraid :{
Jul 15, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Acer Aspire 5630-6288 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
