Question about Abit Computers & Internet
I have an abit av8 mother board and am tryng to install a new power supply (G7 powr exteme) the LED2 is flashing with with no constnt power availabe to power up te system please help is my board or th
ABIT AV8 Motherboard LED 2 flashing and clicking G7 Power Extreme power supply brand new
  • Abit Master
  • 3,606 Answers
Hello here is the homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
You have probably connected the +12 volt 4 pin, connector wrong.
The pci-e graphic connector, sometimes fit here.
When this happends the mainboard will not boot up.
Try to read the manual for the power supply.
Good luck
Posted on Feb 17, 2013
5 Suggested Answers
SOURCE: recieving error code FF and pc will not boot/recognise harddrive
the problem it is in harddisk
is that u have ur smp (power supply)
just check the power supply & insert the cable
properly in to the slot of motherboard & check whether the display has come if it comes than boot the xp cd if problem occurs go to nearest shop of computer
Posted on Dec 04, 2008
SOURCE: cannot get sata drives reconized on my abit av8
i required mother board drivers for asus
p4vp-mx
Posted on Jun 09, 2009
mace1mace
  • 1138 Answers
SOURCE: abit av8 bios post codes 8.3 - 8.6 - 9.C
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
Posted on May 24, 2010
  • 11800 Answers
SOURCE: help needed to connect power cables to Abit AV-8 mother board
Bottom right you will see a set of pins  - 2 rows on a black base, color coded: these are the system pins. Next to them you will find printed on the board the description of the connections to them - follow it.
Posted on Jun 22, 2010
Help needed to connect power cables to Abit AV-8 mother board
Jun 22, 2010 | Abit AV8-3rd Eye Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Cannot get sata drives reconized on my abit av8 motherboard.
p4vp-mx
Jun 09, 2009 | Abit AV8 Motherboard
WON'T START
It might not start because you might have a shortcircut Warning !! your computer hardware can damage or a fire can start replace mother board or new hardware you installed
Jan 17, 2009 | Abit VI7 800MHz FSB VIA PT800 Chipset DDR...
Computer wont turn on trys to but keeps restarting itself
83 - 96 - 9E (for a **** second)-9F
on the post code definition display on the mobo.
When it hits 9E it has shutdown and reads 9F when totally powered off.
I have read on other newsgroups that the power supply might be at fault
I took this from an overclocking forum, I hope it helps
Dec 20, 2008 | Abit AV8 Motherboard
Recieving error code FF and pc will not boot/recognise harddrive
Dec 04, 2008 | Abit AV8 Motherboard
ABIT AV8 not reading SATA ASUS DVD Burner
you should contact your computer servicing centre.the problem might be of the drive.for getting more knowledge about the ASUZ mother board and SATA please make use of your users CD which is given with every ASUZ motherboard.easily understandable pictorial reprasentation of the whole mother board are given there.by that you can even find out the problem in *********** board if any. if you are convinced please rate me
Sep 22, 2008 | Abit AV8-3rd Eye Motherboard
Desktop
most likely your guess is correct and if a beep sound is not availabe (Power good signal) than its 100% power supply problem.
Apr 26, 2008 | E-Machines eMachines Desktop PC
Abit av8
Ensure that you got the cpu fan connected to the correct place, the board has 2 one for the cpu fan andt the other for a system controlled case fan.
If that dont work check to see you got the power supply connected to the board propperly, there is a seperate 4 pin connector using 2 yellow and 2 black wires ensure it is correct.
Check your power supply
unplug the power supply and bridge the green wire with the black one next to it to see if it comes on. OR JUST CHANGE THE POWER SUPPLY TO SEE IF IT WORKS.
YOUR PROBLEM IS A POWER PROBLEM EIGHTER FROM A BAD CONNECTION OR A WRONG HOOK UP AND IF NOT THAT A BAD POWER SUPPLY
Jan 03, 2008 | Abit AV8 VIA K8T800 Pro Socket 939 DDR 400...
Computers & Internet Logo
141 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
