Question about Sewing Machines
My wife has a pfaff simplamatic 571 sewing machine which has a timing problem - it thread gets tangled and does not seem to pick up properly. I have searched the web for some reference to this machine
I am trying to find out how to time this machine -there are no timing marks as far as I can see and I do not know how far the needle should project into the basket when at the bottom. I have read that the hook should be <> 1/4inch behind the needle what it is at the bottom does this apply to this machine?
SOURCE: bobbin tangle
can not thread bobbin...bobbin on top
Posted on Apr 27, 2008
  • 323 Answers
SOURCE: Thread breaking.
Rethread the machine following these directions:
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them.
Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works.
Make sure the thread is through the take up lever.
sewman7
Sewman7
Posted on Jul 10, 2008
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
kevin000
  • 1847 Answers
SOURCE: consew 226 r sewing machine
Take the bobbin out and check for dirt or broken thread in the hole.
Posted on Sep 15, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
Bought a Pfaff 230 sewing machine I have threaded the. Achieve e made sure the bobbin was in right and the bobbin thread will not pick up
Make sure you have installed a brand new needle. If the problem persists, most likely the machine is out of time. Search for sewing machine timing or take it for service.
Mar 30, 2017 | PfaFF Sewing Machines
Pfaff 1196, needle won't pick up bobbin thread. Can I fix that?
First, be sure you install a brand new needle. Old, damaged needles frequently will not pick up the bobbin thread. If not that, then the machine is out of time. Search the internet for sites and videos discussing sewing machine timing or take it for service.
Dec 18, 2016 | PfaFF Sewing Machines
Why Doesn't my sewing machine want to pick up the bobbin thread correctly?
if the bobbin case isn't turning properly are you sure you it in right.
Hold the lever on it out, slide the case on the spindle all the way and then release the lever. Also try a different length needle, it may be to long to allow a uniform stitch
Jul 12, 2014 | Brother CE8080PRW Limited Edition Project...
Thread jamming in bobbin when i use walking foot
Had a similar problem with our Pfaff. Needed a replacement cam. broken gear.
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
Feb 09, 2012 | Brother CE5000 Computerized Sewing Machine
The macine said it was an E6 error thread jam which I completely cleaned the bobbin area (not much there anyway) but I still cannot get it to not jam the thread on the botom. I have changed needles also.
Hello
This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Jul 11, 2011 | Brother CS-100-T Computerized Sewing...
Sewing Machines Logo
54 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
