Question about Armstrong Astro 230 1/25 HP Recirculator Pump 110223-305
Armstrong astro 230ci recirulator pump troubleshooting
Will not automaticly come back on
2 Suggested Answers
  • 61 Answers
SOURCE: how to wire to 120v and thermostat on a armstrong
A line voltage thermostat is just like any other type of switch, except that it's controlled by temperature.
Just wire the 120vac to the pump, but interrupt the hot (black) wire with the thermostat.
Let me know if you need more help.
Posted on Oct 30, 2009
Heavy duty astro model 457864 how do I set the event timer
[PDF]24-HOUR TIMER AND AQUASTAT CONTROL ...
armstrongfluidtechnology.com/.../11_871_astro2_timer_and_aquastat_i-...
Jun 3, 2015 - 9.0 Timer programming with manual override switch 3. 1.0 Timer ...eration of the circulating pump during high peak usage periods in order to ... pm timesetting. 2.0 aquastat ... 2 Astro 2 Series circulator and 24-Hour Timer wiring diagram.... In the event of power outage, the timer must be adjusted for.
Oct 28, 2015 | Astro Systems Armstrong Astro 20B050S-TA...
Wiring a armstrong astro 30 circulating pump
If it is 120 volts it's quite simple. First make sure to turn off the heat at the red emergency switch. This will not affect your system. Simply turn the switch back on when you are done. Remove the cover off the small box on the side of the pump. There should be one screw holding it on. You should be feeding the pump with BX cable from the controller (Aquastat or pump relay). Older steel BX carries the ground through the cable, and the connector, but the newer, aluminum BX has a ground wire inside the cable.Remove about four inches of the BX cable from around the wires. Just bend the BX at the designated length until it breaks. Twist the cable clockwise in one hand and counter clockwise in the other. This will open it enough for you to snip the cable,(not the wires) with dikes or tin snips. Or, you can unravel the BX from the open end. Be careful. BX is sharp. Insert a red head (anti-short) around the two or three wires and slide it into the cable leaving the four inches of wire still outside the cable. Install a 1/2" BX connector into the the round opening provided on the box. Screw the nut onto the connector hand tight and tighten the nut by placing a flat screwdriver onto one of the nubs on the nut and tap it around with the heel of your hand or any pliers or hammer if available. Slide your wires through the connector until the cable bottoms out inside the connector. Tighten the connector set screw. Now you have a black, a white, and possibly a green wire inside the box. Strip about 3/4" of insulation off of each wire. The three wires in the box on the pump should already be stripped, but if not, strip those too. Twist the wires together using your hands or pliers. White with white, black with black, and green with green. This ensures a good connection. Now, you can twist your orange wire nuts on to the pre-twisted wires. Use orange nuts because they are smaller and will fit into the small box better than yellow or red nuts. To ensure a proper splice, twist them until the wires start to twist in your hand . Fold the wires into the box, install the cover onto the box making sure not to pinch the wires and turn the emergency switch back on.
Oct 20, 2012 | Armstrong ASTRO-30 CIRCULATOR PUMP
I have a Amrstrong Astro 25B050S recirculating pump on my 50 gallon State water heater (both installed in 2006). The timer works fine and the I can hear the Astro pump and the pump feels very hot to the...
If the pump is very hot, unplug it.
Heat damages motor coil and indicates that pump is not rotating at correct speed, or not rotating.
Take apart and clean inside pipe with white vinegar or CLR to see if pump rotor can be freed to rotate.
If pump does not rotate after cleaning, then replace pump.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Aug 16, 2011 | Astro Systems Armstrong Astro 20B050S-TA...
Hot water still takes two min. to go 50 feet . also is causing pipes to rattle. how is timer set?
It sounds like you have a 'crossover' problem.
Crossover means that cold water is getting into cold water pipe, and stopping hot water from flowing directly down the pipe.
This can signal a bad recirculation check valve, or a bad single-handled faucet cartridge.
Read how to test for crossover:
http://waterheatertimer.org/pdf/Crossover-on-single-handled-faucet.pdf
Also read about basic recirculation systems:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Astro Systems Armstrong 20 BU-T Astro...
Where is the reset button for the armstrong circulating pumup s 25 bf located?
There is no reset... if you have power and it is not running then the pump is toast...
replace it...
heatman101
Apr 30, 2011 | Armstrong Tool Armstrong S25 BF InLine...
Gas Armstrong Ultra V Tech 91-Is green light supposed to flash?
Installed a new filter and furnace is running great now. The old filter was not that old, but we have been doing some remodeling and I figure that is what clogged it so fast.
Jan 10, 2010 | Armstrong H 67 1PH Bf In Line Circulator...
How to wire to 120v and thermostat on a armstrong astro 30 pump
Oct 17, 2009 | Armstrong Plumbing
Armstrong Astro 230 1/25 HP Recirculator Pump 110223-305 Logo
Top Armstrong Plumbing Experts
Boyet Soriano
Boyet Soriano
Andrew Bugbee
Are you an Armstrong Plumbing Expert? Answer questions, earn points and help others
