Question about Zenith Vintage Compact Vhs-c Hardcase With Battery, Cords, Lens, And Light
1985 zenith video movie VHSC compact auto focus camcorder manual
Need manual for repair and knowledge
Would someone help me find the manual for jvc compact vhs gr ax-10?
I could not find a manual for that specific one, however I did find this: http://www.ebay.co.uk/itm/JVC-VIDEOMOVIE-GR-AX10-CAMCORDER-VHSC-VHS-C-/380362198096 You may contact them and see if maybe they would make copies of it and send them to you for a minimal fee?
Sep 17, 2014 | Video Cameras
I have an everio camcorder GZ-MG155U. It will only focus on 9X, 10X, and 11x. Anything else gets blurry. I have tried auto focus and manual focus and nothing works. I also tried resetting to the...
The most likely cause for this is a zoom or focus lens out of place or impaired in some way and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Aug 11, 2011 | JVC Everio GZ-MG155 Camcorder
Can't seem to select any Auto Focus from the menu...it stays "greyed out" no matter what I do...it will manually focus, but auto focus cant be turned on.
If your camcorder is in "EASY" operation, it will not allow you to change certain features in the menu. On the other hand, if your camcorder is in "EASY" operation, it should be autofocusing.
Hope this helps you in some way.
www.austintelstarservices.com
Jul 20, 2011 | Canon VIXIA HF10 HDV Camcorder
While recording the Camcorder goes in and out of focus. If I keep the camcorder running and either zoom or pan out the subject refocuses, but if i hold at that level of focus the subject becomes blurry...
It sounds like you are either too close to the subject or you need to flip the focus switch to automatic.
The Auto/Manual focus button is located on the left side of the camcorder under the LCD monitor flap.
Other than that, does this happen only in low light? The camera will have trouble focusing in low light usually.
Mar 01, 2011 | Panasonic SDR-H40 HDD Camcorder
Videos won't convert properly to Windows Movie Maker and more.
try burning onto a dvd from adobe then manually uploading the footage from the dvd to the movie maker. Sometimes movie maker will not do auto if footage is out of focus....balance....or is too shakey.
Jan 07, 2009 | Sanyo Xacti VPC-HD1000 Flash Media...
Need Manual
Display Optical Viewfinder Yes Optical VF Type Optical LCD Viewfinder Yes LCD Size (inches) 1.5 Power Battery Form Factor 2 x AA or 1 x CR-V3 Usable Battery Types Alk. / Lithium disposable, NiMH rechargeable Batteries Included 2 x AA Alkaline disposable Battery Charger Included No Flash Internal Flash Yes No of Flash Modes 4 Flash Modes Automatic, Fill (On), Off, Red-eye reduction Flash Range Description Unknown Ext Flash No Connectivity Video Out Yes Video Mode Switchable Yes External Connections USB 1.1 Other Connection DC In Included Software Unknown OS Compatibility Windows, MacOS Image Storage Usable Memory Types SD/MMC Other Memory Types Built In (8MB) Memory Included (MB) 8.0 Uncompressed Format None CCD Raw Format No Compressed Format JPEG (EXIF 2.1) Movie File Format MotionJPEG (AVI) Image Capture Image Resolution 1280x1024, 640x480 Movie Resolution 320x240 Aspect Ratio 4:3 CCD Sensor (Megapixels) 1.30 CCD Manufacturer Unknown CMOS Movie Audio No Quality Levels 3 Lens Digital Zoom Yes Digital Zoom Values 2x Auto Focus No Manual Focus No Normal Focus Range 120 cm to Infinity
49.0 in to Infinity Max Aperture f/3.0 Aperture Range Description f/3.0 Lens Thread Type None Exposure Number of White Balance Settings 5 White Balance Settings Auto, Sun, Shade, Fluorescent, Tungsten Manual White Balance No Longest Shutter Time 1/20 Shortest Shutter Time 1/2500 Exp Adj Range 1.5 EV Exp Adj Step Size 0.30 EV Metering Modes Auto Spot Metering No Aperture Priority No Shutter Priority No Full Manual Exposure No Self Timer 10 seconds General Model Number 3315 Camera Format Compact Currently Manufactured No Retail Price $99.00 Street Price $105.00 Price Update Date 2003-10-07 Date Available 2002-07-22 Remote Control No Tripod Mount Material Unknown Operating System Windows, MacOS Weight 120 g
4.2 oz Weight With Batteries? No Size 108 x 59 x 36 mm
4.3 x 2.3 x 1.4 in Warranty in Months 12
Oct 26, 2008 | Vivitar ViviCam 35 Digital Camera
Focus trouble
If your unit has a switch for manual focus, put it in manual. If you cannot focus the unit in manual you have a problem with the lense and it will need repaired and/or replaced. If you do not have manual focus you will not be able to troubleshoot the unit. It could be a lense problem as stated before or a problem with the Auto Focus system, perhaps just out of adjustment, or something more serious. Either way if you are not capable of camcorder repair you will have to seek the help of a reputable repair shop. Good luck.
Jun 12, 2006 | Samsung VP-W70U Camcorder
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Can I connect my VHS-C or S-VHS-C camera to my computer?
Since VHSC camcorders feature only analog outputs: it is not possible to connect the camcorder directly to a PC (unless a computer video card is equipped with analog inputs). The only way to transfer images from the camcorder to a PC will be using an external device capable of analog/digital signal conversion. JVC has released a capture device model, GV-CB3U which has the capability of video capture of a single frame in either Bitmap or JPEG format. The GV-CB3 can be connected to any video source through a standard video or S-Video connector and download single image to a PC using serial port (RS232C communication port). The JLIP Video Capture software necessary to transfer images to the computer as well as connecting cables are supplied with this product. You can also use 3rd party hardware (Video Capturing device) to send information from your camera to a PC. Visit your local PC or Office store for more information on other video capturing devices.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Zenith Vintage Compact Vhs-c Hardcase With Battery, Cords, Lens, And Light Logo
Top Zenith Photography Experts
Tony
Are you a Zenith Photography Expert? Answer questions, earn points and help others
