Question about Lexmark Prevail Pro705 Wireless All-In-One InkJet Printer
I have replaced all the inkject cartridges, but nu solution. I stopped the printer, and restarted, but no solution the guidance to "change" the printerhead do I not understand, since I don't find the printerhead. According the pictures they show me a new printerhead, but on that place are the cartridges sitting....
  • Official Brand Answer
  • 3,344 Answers
The printhead might be defective. If your printer is still under warranty, please contact our technical support team to have the printhead replaced. If not, you can purchase a printhead online at http://bit.ly/ghfW8H
Posted on Nov 09, 2012
Ajkill
  • 2035 Answers
SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Posted on Mar 15, 2008
d2704
  • 101 Answers
SOURCE: Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Posted on Mar 07, 2009
57 varieties
  • 1653 Answers
SOURCE: Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Cartridge Error
Posted on Nov 10, 2009
rh10
  • 122 Answers
SOURCE: Cartridge Error # 1203 when replacing black ink cartridge
It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
Posted on Jul 16, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Message:" There is a problem with the printhead.
    Make sure your printer is updated. The firmware update, available in the Lexmark website, will help fix printhead-related problems. Follow these steps: 1. Remove the printhead from the printer.
    2. Reset the printer by unplugging the power adapter from the printer (should be the whole black box on the back of the printer), leave it unplugged for about a minute then plug it back in.
    3. Once the printer is back on, it will ask for the printhead. Just disregard the message by pressing or CANCEL button on your printer screen. Do not install the printhead yet.
    4. Then, please use this link: http://bit.ly/p705fw to download and run the firmware on your computer. Please make sure that the USB cable is attached from the printer to the computer while you do this.
    5. Once the firmware update is complete, you may reinstall the printhead.
    Posted on May 04, 2011
    SAMSUNG CLX-3175 how to enter the tech menu
    Press: Menu # 1 9 3 4 OK Menu
    Tech Mode / Tech Menu should now be shown on screen
    Mar 19, 2012 | Samsung CLX-3175FN Color Laser All-in-One...
    Samsung SCX-3200 FUSER UNIT FAILURE #U1-2113
    fuser unit failure #u1-2113, how to solve this problem?
    Jan 15, 2012 | Samsung Office Equipment & Supplies
    On HP Photosmart 7960, which cartridge to replace when the blue and green look pale
    The printer takes a tri-color cartridge and a black cartridge. So anytime there is an issue with color, replace the tri-color cartridge. As far as using compatible inks, you will not be able to use HP's software for ink levels with compatible inks. This feature will work only with HP ink cartridges.
    Oct 23, 2011 | HP PhotoSmart 7350 InkJet Printer
    To know when ink needs rep
    With compatible ink you will just have to watch for colors fading. HP software supports only HP ink, so the ink monitoring software will not function with compatible cartridges
    Oct 21, 2011 | HP PhotoSmart 7960 InkJet Printer
    I can't seem to figure out how to get the ink cartridge out of the printer.
    Here is a video on replacing the in cartridge, I couldn't find one for your exact model but for inkjects they are all pretty close.
    Jan 07, 2009 | HP Photosmart 3180 All-In-One Printer
    How to refill hp 818 inkjet cartridge
    on 818 hp cartridge five holes are there, which colour ink on which hole i have to put ink on them
    Dec 03, 2008 | HP DeskJet F380 All-In-One Printer
    Lexmark Prevail Pro705 Wireless All-In-One InkJet Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
