No face lighting or volume knob lighting on harmon kardon avr 1650 not remote dim button)
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Posted on Oct 30, 2007
SOURCE: harmon kardon avr 25 ii
I upgraded my HK AVR 20II and ran into the same problem when I tried to hook the old unit up out in my garage.
Luckily I remember that on the rear there is a pre-out RCA port (L/R) and a Main-In port that are intended to be to/from an equalizer/amplifier. These come jumpered out of the box, but I had been using an equalizer so the jumpers were long lost.
Assuming you also have no amp/eq you are using, just connect the Pre-Out to the Main-In using a standard M/M RCA cable and you will be in business. (turn the volume down first!)
Good luck.
Posted on Apr 25, 2009
mlapres
  • 757 Answers
SOURCE: Harmon Kardon AVR 235 no sound
Ensure that your speakers are connected to the terminals that you have your speaker selector switch turned to.
Then check that you have your device, whether it be a CD or DVD player, or turntable, plugged into the correct input and that you also have the correct input selected on the receiver.
Posted on Dec 30, 2009
SOURCE: My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Posted on Apr 10, 2010
SOURCE: My Harman/Kardon AVR 140 is stuck on stand by mode
Try unplug the power. Wait a few minutes. Reconnect the power.
Posted on Jul 25, 2010
Avr 520 will not turn on with my remote tried all codes the unit will turn off and works with remote but i have to turn on manually
Could be that the "on" button is not making proper contact on the remote and the other buttons do work. To confirm place remote on top of an am radio tuned to about 600 on the dial, turn up the volume and start nailing the buttons on by one.
You will hear a beep for each button you press. If nada for a button then it is bogus. U can try cleaning the contact of the remote for that button or maybe even use a very small piece of tin foil on the remote itself for that button. If nothing helps the only solution might be expensive if you decide to replace the remote.
Aug 29, 2015 | Harmon Kardon Harman/kardon Av Surround...
How can i make the sky remote control th avr 130 (harmon kardon)
Does the sky remote have a code for the HK receiver? If it does, use that code to program it. Most other remotes won't work completely because this receiver uses a seperate button to turn it off...
Mar 14, 2010 | Harman Kardon AVR 130 Receiver
Dec 29, 2009 | Harman Kardon AVR 235 Receiver
Need starchoice codes for Karman Kardon AVR 220
http://www.starchoice.ca/english/customercare/techcentral/remote_controls.asp
Look here for the codes to whatever remote you have. The chances are there arent any though. Harmon Kardon codes are a very unique signal that most remotes cant duplicate. More than likely you are going to have to use the original Harmon Kardon remote.
Oct 24, 2009 | Televison & Video
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Learning remote codes for my harmon kardon avr354
a) Place the two remotes so that their IR transmitters face each other
end to end, separated by about one inch. The
AVR 354 remote’s transmitter also serves as an IR receiver during
the learning process.– AVR 354 and Original Remote Head-to-Head
b) Press the Source Selector for the device mode you wish to learn
a code into, and place the AVR 354 remote in Learning mode by
pressing and holding the Learn Button until the Source Selector lights
up, then release.
Learning Remote Commands
c) Press the button on the AVR 350 remote you wish to program with
the new code, and the Source Selector will flash once. You may
learn a new code into the following buttons: Device Power On/Off,
Alphanumeric Keys, Last Button, Back/Exit Button, Menu Button, Navigation Buttons, OK Button, Disc Menu Button,
the four Teletext Buttons, Channel Up/Down, Volume Up/Down,
Mute and the Transport Controls (including Record).
d) Press and hold the button on the device’s original remote whose
code you wish to “learn” until the Source Selector flashes three
times, then release.
e) You may program additional buttons by repeating steps c) and d).
Press the Learn Button once to exit Learning mode, or wait for the
remote to “time out” and exit Learning mode on its own after about
30 seconds.
Dec 11, 2008 | Harman Kardon Harmon Kardon SoundStick II...
I HAVE A HARMON KARDON AVR 310 RECEIVER. I HAVE NOT USED IT IN ALMOST A YEAR BUT I REMEMBER IT BEING COMPLICATED TO USE. I WENT TO USE IT YESTERDAY, AND IT POWERS UP FINE, BUT WHEN YOU TRY TO PLAY...
Hi - You can download the manual by clicking the link underlined in blue below:
AVR 310
You're right this is a complicated beast to set up! I suggest you go through the manual & follow the setup guides there.
Possibly the unit has been muted via the remote control?
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 15, 2008 | Audio Players & Recorders
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
Avr 35 volume control
Are you using the two small silver touch + and - controls that are set close to the bottom of one sound stick? They are very discrete and easily missed. (I did at first.)
Nov 29, 2007 | Harman Kardon Harmon Kardon SoundStick II...
 Grubhead
Grubhead
