I cannot open the door to my aeg lava mat turbo washing machine L12710VIT
  • 3 Answers
Most washing machines have a childproof locking mechanism, these can either be electrical or mechanical.
If you forced it you may damage something.
I would recommend contacting a Repair engineer (some do a free call out or advice over phone) or use an recognised AEG Technician for a fixed price repair
If item is out of warranty please contact me for where to claim?
Posted on Nov 09, 2012
  • 1294 Answers
SOURCE: aeg lavamat 538
Your door will not open if there is water still in the machine. Try "spin only". If this fails, get a bucket, remove your outlet tube from the wall drain, put into bucket. Wall plug off first. After all the water is drained try the door, do not force it.
Then check your outlet filter; the water does not go thru for there may be a block in your filter, or tube from the tub to drain area. Or finally in your pump. Dont forget to refix drain pipe in wall in exact position.
And rate me pl.
Posted on Dec 01, 2007
SOURCE: Door locked
Rather than taking the top off the machine and fiddling around to find the catch as guest suggests, I got it to open with some strong string. I took a fairly long piece and threaded it into the groove where the door joins the metal front of the machine, on the catch side of the door. Then pull both ends of the string very hard to the left (you may want to wear gloves to protect your hands). Pull hard and move the string up and down until the door opens. Worked for me.
Posted on Feb 15, 2008
SOURCE: AEG LAVA COMBO 1000
check your timer maybe the motors inside is defective, or your wiring is cut by the rats, or your timer itself is defective, the contact is not working properly.
Posted on Apr 14, 2008
Benimur
  • 6966 Answers
SOURCE: AEG Washing Machine: Door won't close
Hi again,
Any updates/development with your project?
Posted on Jun 21, 2008
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
When I switch on my washing machine AEG Lavamat turbo 16800 it displays E40
HI Mike.
THIS IS ALL I COULD FIND OUT.
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.
to solve the problem get another switch.
hope this helps you.
or read up some more at this link.
washing machine AEG Lavamat turbo 16800 it displays E40 Google Search
Dec 20, 2017 | AEG Washing Machines
My Aeg lava mat 9000 display and push button panel has disappeared in casing
The circuit board the buttons are on has fallen off the faceplate bezel. Open the cabinet to see if a plastic tab has broken off or some other attachment has failed.
Oct 24, 2016 | AEG Washing Machines
How do I dry with a oko lava mat 61600
I have spent a lot of time going round in circles. Some sites say that model is a washing machine and not a washer dryer, others say it is a refrigerator!
The machine is made by AEG. If you go to the AEG homepage and put your country in, it may be country specific. I tried Australia, and the UK, but nothing came up with that model number.
Select country and then Support/Manuals.
http://www.aeg-home.com/
Welcome to AEG
Jun 13, 2016 | Dryers
Only 1 programme working
I Have a Lava mat 72600 and it came up with E9 as this is not in the
manual what should I be looking for? The machine gets redy to let the water in and it just makes a click is the solonoid Jammed or somthing else thios sems a comon prob as it is a question asked elsewhere.
Also how do you get the top off with out breaking somthing?
Aug 06, 2009 | AEG Washing Machines
Lava-combo 1100
Hi This machine is made by AEG
You really need the PNC number which is on the rating plate..
Then go here
http://www.aeg.com/node441.asp
and search for the manual
Please leave feedback
thanks
Rob
Feb 12, 2009 | Washing Machines
AEG LAVA COMBO 1000
SORRY, UNFAMILIAR WITH AEG PRODUCTS
Mar 30, 2008 | AEG Lavamat W1450 Front Load Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
