Question about Sony KDL46HX820 3D LCD TV
Sony Bravia KDL46HX820 conks off suddenly and 4 blink error.
I bought last year a new Sony Bravia KDL46HX820.Y-day we were watching a movie and suddenly switches off by itself and then the red light led blinks four times and pauses and then blinks again. I tried to power off and on but no use. I called the customer support and they asked me to contact a nearest service center.Did anyone seen this issue and if so whats the solution and how bad is this issue in terms of future stability and service costs which will incur now on me..
redhead7377
  • 51 Answers
SOURCE: Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
Posted on Sep 09, 2008
mistersony
  • 320 Answers
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Posted on Oct 18, 2008
mistersony
  • 320 Answers
SOURCE: sony bravia KDL40S2000 standby blink four times
A 4 flash issue means either the back light inverter (power supply) has failed or that one of the fluorescent tubes in the panel has failed. The only way to know for sure is to check the fuses that are on the inverter board. If one or more of the fuses are opne, then it is likely the inverter board is bad. If the fuses all check good, then the panel is at fault. If it is the inverter board, it is a part you could replace yourself; the cost of the board is about $70. If it is the panel, you would probably want to consider replacing the TV, as the repair costs would be over $1000
Posted on Dec 10, 2008
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
SOURCE: tv shuts off spontaneously. red power light blinks.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
Posted on Aug 29, 2009
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
What does 4-blink error code indicate?
These may help - the first just tell what it is and which ICs maybe the problem (quite technical)
Solved Sony Bravia Blinking Code
Bravia KDL46EX720 Red LED blinks 4 times and TV wont turn on What is the...
or, in the last resort you could try Sony support, either to get a service manual, or to ask a technician. Don't be fobbed with an expensive answer as in one the examples above.
Support for LCD TV BRAVIA Sony
18.November.2015
Nov 14, 2015 | Sony KDL-46EX720 BRAVIA 46 Class LED 3D...
1year 2months old Sony Bravia KDL46HX820 powers on for few seconds ; I see black clouds on the top left corner ; TV switches off and 4 red lights blink ; Please advice on what might be the issue
No Vertical Sync is the fault. This is a main board fault. The main board might need replacement. But before confirming, check all the voltages comes to the main board from the power regulator board. If you wish to know more about the voltages and their sources, check this link.
Jan 30, 2013 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Sony Bravia KDL46HX820 powers off and throws 4 blink and pause error
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Jun 09, 2017 | Sony KDL Televison & Video
My Sony Bravia turns itself off Stand by red light blinks twice.
If you bought it brand new from a dealer, I would take it back or have them come out and look at it. Less than a month old, it is still under the 1 year MFG warranty or the very best a 30 day one.
Jun 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia 46''
It sounds like it is defective, you have warranty call for service!
Jun 13, 2008 | Sony BRAVIA KDL-46V3000 Television
Sony BRAVIA KDL-52W3000
I would take that puppy back to store and get exchanged out. According to lemon law. Let me know what happens. Thank you Jay.
Jan 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KDL46HX820 3D LCD TV Logo
743 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
