Question about Foxconn 865M01-G-6LS Motherboard
Brand new cant seem to boot windows os. These errors keep appearing no matter what I tried. PXE-E61 and PXE-MOF. What should I do? I bought a asus cusl2 motherboard and no problems with that motherboard, but this one seems to give me all kinds of problems. What should I do?
  • 883 Answers
First go full bare-bones...only video, keyboard,mouse turned on in BIOS. then re-install windows. if still no good repeat above steps except to add this step just before windows: run fdisk to re-partition the drive and then run format using the svs switch...then re-windows. if successful, then turn on system restore to create a restore point and re-boot before any new devices are added to system
Posted on May 24, 2007
SOURCE:
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
Error message on dv 1000 pxe-mof and pxe-e61
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 17, 2013 | HP Pavilion dv1000 Notebook
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 10, 2012 | Dell Computers & Internet
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
WHEN I CUT ON MY LAPTOP..AFTER REINSTALLING WINDOWS XP.. ERROR ERROR FOR.. RELTEK RTL8139X/8130/10X PCI FAST ETHERNET CONTROLLER V2.13 020326 PXE-E61 MEDIA TEST FAILURE CHECK CABLE PXE-MOF EXITING...
the system is trying to boot to the Network adapter. If the system boots into Windows after the error, then all you need to do is change the boot sequence in the BIOS (Resetting defaults will likely fix this)
If system is not booting into windows after the error then you may have a hard drive fault
Sep 09, 2010 | Computers & Internet
Acer aspire 5315 will not boot up, indicating no bootable device
Sounds like you wiped out the harddrive try reinstalling the os if that does not work you may ned a new harddrive
Mar 16, 2009 | Acer Aspire 5315 Notebook
Toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
Jun 16, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Foxconn 865M01-G-6LS Motherboard Logo
114 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Thomas F. Schneider
WTF Chuck.....
WTF Chuck.....
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
