Question about Whirlpool duet Washing Machines
Whirlpool Duet Sport F33 error code - duet Whirlpool Washing Machines
aborcass
  • 2651 Answers
SOURCE: whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
Posted on Mar 12, 2009
  • 240 Answers
SOURCE: Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Posted on May 02, 2009
SOURCE: Whirlpool Duet Sport Error Codes?
My machine had the F21 code and the inlet to the pump was blocked with change, bobby pins, small rocks, pieces of fuzz and clothing. Removed the front cover of the mahine and removed the cap on the front side of the pump and cleaned this trap area out. The pump motor quit humming and the machine worked like it is supposed to!
Thanks
Posted on Sep 09, 2009
  • 662 Answers
SOURCE: F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
Posted on May 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet sport washer F21 & F33 codes
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
The waher quits working and F33 shows up on the front
F33 error code indicates a pump drive system error.
If the pump ohms out correctly and the harness is secure and working fine, I recommend replacing the CCU (central control unit).
Good luck.
May 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F 33
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
Mar 04, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Fault code f-33 on a whirlpool duet.
The F33 code is a pump failure code. The control unit is not measuring the proper amp draw on the pump during pump out. Remove lower panel and unplug then replug in the pump 2 or 3 times to remove any corrosion. While your down there, take the front of the pump off to check for any blockages.BE SURE TO UNPLUG YOUR WASHER WHILE SERVICING!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washeer has f33 code
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer codes F01/F33, have cleaned the pump and
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an f/33 error message on my whirlpool duet washer how do i fix it
Apr 26, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I have an f33 error code on the whirlpool duet front loader please help me to fix this.
F33 = PUMP DRIVE SYSTEM ERROR
When the connection between pump and the Central Control Unit (CCU) is lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Faulty CCU < call for service >
Nov 10, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet sport. I am getting a f33 error code.
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
12 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
