Question about Lexmark Office Equipment & Supplies
Phone line error comes up on the printer. cannot send faxes.
I have tried everything I can think of. I checked the phone line & it is fine.
    Genius:
  • 2,120 Answers
Do you have Digital, DSL, Vonage, or a Cable phone Line?
Fax machines only work on ANALOG phone lines.
Posted on Jan 05, 2009
Hi my HP printer fax was working fine but now I am getting a 351 error message I rang the fax print test and everything seemed fine there
    1. On the product control panel, press the setup button (c01661990.gif ).
    2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
    3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OKbutton (c01335940.jpg ).
    4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
    5. If the ECM is off try turning it back On
    6. Check All these other settings
    7. Press the Setup button c01661990.gif Go to Advanced fax settings and check if the Fax speed is set to medium
          Oct 24, 2010 | HP Officejet 6500 Wireless All-in-One...
          Receiving faxes, won't send faxes. Comes up line
          Your fax machine thinks everything is OK. If you can receive you can send.
          call the failing fax number with a regular phone and listen for fax tones.
          Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
          We have a HP colour laser jet CM2320nf MFP and when we try and send a fax it comes up with error report Comm Error 345. Please explain
          Check phone line. use a normal phone and plug into the same phone wall socket that the MFP is using, do we have a dial tone? Do we have a noisy line, any buzz or crackel will cause issues
          If there is no dial tone ring line supplier, If it is noisy line do the same
          Also check phone line is plug into "line" socket in the back of machine not "ext'
          Also check no prefix is required to dial out, unit needs its own phone line..
          Also try using resolution of fax as standard not fine, this requires less info to go threw the line
          In Australia we have a thing called folds (fax online diag service), basicly it is a fax number you ring and the phone company who own the line send back a report, most times the issue is noisy line or no line available
          hope this helps
          Cheers
          Soulvisitor
          Nov 27, 2009 | HP Laserjet CM2320nf All-In-One Color...
          Hp 3030 will not send faxes or receive them
          Check the phone line with a regular phone.
          Plug phone line into the LINE port.
          Feb 01, 2009 | HP LaserJet 3030 All-In-One Printer
          Fax interrupts phone call
          1. Make sure your [RINGS TO ANSWER] settings are more than the same settings for your answering machine.
          2. If someone tries to make a copy while the phone line is in use, they need to press number 1, as if telling the unit that they want one copy. If not, the unit will think you are trying to receive a fax and will interrupt the communication.
          Be blessed.
          Sep 04, 2008 | Samsung CLX 3160fn All-In-One Printer
          Fax machine stoped receiveing fax
          First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
          You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
          Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
          My Lexmark X4270 will send out faxes but when someone sends me a fax it rings once and no face comes through. I have been trying to figure this out for weeks. Please help. I need it for my buisness and I...
          95 percent of the time that is a phone line issue.
          If there is more than one item on that line, it can be an issue.
          I will throw out everything since I am not there.
          A DSL or digital phone line can cause that problem. The majority of fax machines still require an analogue phone line.
          Make sure that Junk Fax is off, secure fax is off, and that the ECM mode is ON. ECM is error correction mode.
          Also be sure manual receive is not turned on.
          I strongly suspect a phone line issue. I will explaine.
          There are 3 phone line conditions that have to be correct for a fax machine to pick up. 1 is the phone line voltage, 2 is the phone line current, 3 is what is called decibel loss.
          The reason you can send and call out on the line is that you manually turn "on" the phone line when you pick up the phone or when you select send on a fax, it is manually switching a relay to connect to the phone line.
          When you are receiving you need the correct signal level to activate the fax. Think of how it is when your TV/VCR remote has weak batteries. You press the button and sometimes it works most of the time it doesn't. The volatge on the battery will still read 1.5 volts, but you dont have enough current draw or wattage to get the proper signal to change channels or turn the sound up and down. Same concept. But when you walk up to the TV/VCD you push the buttons it works fine. Very same concept.
          Mar 14, 2008 | Lexmark X4270 All-in-One Multifunction...
          Brother mfc-5840cn
          press menu then start mono then 4 times arrow-up (Tel index). machine will be in maintenance mode. press 8 then 0 (zero) then press the start mono button until display shows error A1: xy. Press the right arrow (Speaker +) button. What error codes do you see? (Machine saves the last ten errors). plz post here again.
          To leave the maintenance mode press 9 then 9.
          Nov 02, 2007 | Brother MFC-5840CN All-In-One InkJet...
          I cannot send nor receive faxes.
          Make sure the phone cord from the wall is plugged into the port marked"line" and not "phone".
          Apr 29, 2007 | Brother MFC-5840CN All-In-One InkJet...
          Canon MP830
          When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
          Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
          193 people viewed this question
          Top Lexmark Office Equipment & Supplies Experts
          Don  Farrell
          Don Farrell
          Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
