Question about Dell Inspiron XPS M140 Notebook
My computer won't boot up
When i turn it on the boot screen freezes. It says PBR 1...done [XLDR] !ATA It will not allow me to do anything, and will not pass this screen.
map9966
  • 2351 Answers
SOURCE: Will not boot completely
Hi dalenaftzger, windows can not load your primary partition. One of your partition is damaged. Dell
Hi dalenaftzger, windows can not load your primary partition. One of your partitions is damaged. Dell systems have more than one partition on their hard disk drives. Two partitions are hidden. Try this;
Start up the computer and press F12 key to give you the boot-up options.
Insert Windows Installation/Recovery CD into your CD-ROM. Choose CD-ROM boot option & press enter.
Let the installation process continue until it prompts you to, Press R to repair. This should then take you into the DOS mode. Type in FIXBOOT & when prompted, press "Y" to start creating the new boot partition. If everything goes right, you should get a message saying the partition was corrupted and a new one was created successfully. Remove the CD & reboot your system.
Play it safe if your system boots windows. Check windows for any updates. Run a full system virus scan. Run windows check disk & windows defrag.
Just in case the drive is starting to go. If you have a CD/DVD writer start backing up your personal data. The most common folder to back up are:
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
Data from any program you may have installed.
Armed with the above folders backed up to CD/DVD, you'll loose very little if you have to replace the hard disk drive.
Good luck dalenaftzger!
Have more questions?
Mike
Posted on Oct 03, 2008
ericram
  • 101 Answers
SOURCE: On boot up screen reads "Loading PBR 2...done"
As the notebook is starting you see the Dell 'Splash' screen. Press F2 to go into the BIOS setup. Check to make sure two things: first that your cd/dvd and hard drive are being recognized and identified, second that your boot order has the cd/dvd first and internal hard drive second. Your machine may be trying to do a USB device boot or network boot when these options are not available. Next try pressing F8 immediately after the splash screen disappears to try to get into Safe Mode. If it still fails to boot, I would try booting using a Windows XP installation disk and then going into the repair console to check if the hard drive is damaged or corrupted.
Posted on Dec 28, 2008
PJBHOi
  • 15 Answers
SOURCE: loanding pbr for descriptor 2 done
hi there.. i'd really hate to say it but you have to reinstall your operating system.. honestly even if your're gonna try running chkdsk/p or /r it still no good it will just waste your time.
Posted on Mar 12, 2009
videotransmi
  • 105 Answers
SOURCE: I have a new Mini and I can not get the thing to
I would recommend that you take it back to the store where you purchased it. Or call tech support if your unit is under warranty. CLICK HERE for a link to Dell Tech support. Good Luck with that!
Posted on Nov 10, 2009
Preeth Tom
  • 129 Answers
SOURCE: First freeze, then boot slow, then boot
The problem is with the corrupted boot files .In my opinion you have one solution
Steps for solution
1. Download an operating system called ' Linux mint ' which can be installed in the pen drive having minimum 4 gb capacity . Using this operating system you can access the computer .
2. Copy the file and folders to an external storage device (external hard disk, pen drive etc..)
3. Reinstall the operating system ( XP,Vista ,Window 7,Ubuntu etc )
Hope you be successful
Posted on Mar 11, 2010
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
I want my monitor to work once again because it says cannot display video mode? i dont understand help me?
You didn't say which OS you're running. However, it looks like you need to restart your computer in safe mode. This URL explains how to get in safe mode. When the computer boots the video it will look a bit grainy and you won't be able to see the entire desktop without using the scroll bars.
Both XP and Vista don't allow you to perform such an operation through the regular procedure and, as a result, you will only be able to get a screen resolution of 800×600 with the consequence that some icons and programs won't be displayed correctly. This is because Safe Mode just loads only basic services and drivers which are strictly necessary for Windows to run.
Fortunately, by employing the following techniques, you can get around this restriction permitting you to get whatever screen resolution you want.
Windows XP:
  1. Right click on your desktop.
  2. Click Properties.
  3. Click the Settings tab.
  4. Under Screen Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced.
  6. On the new window click OK, without modifying anything.
  7. Done, you should have successfully changed the resolution settings.
Windows Vista:
  2. Click Personalize.
  3. Click Display Settings.
  4. Under Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced Settings.
  7. Done, you should have successfully change the resolution settings.
Aug 11, 2011 | Dell 1503FP 15" LCD Monitor
Blue screen when installing os
If you are trying to install the Windows XP from scratch on the computer, please BE SURE that you put the Hard Drive on "Compatibility" mode in BIOS, which was defaulted to "AHCI" (Compatibility is also known as IDE).
Otherwise, you will experience the "blue screen" issue. To change that setting, you need to do the following:
1. Press F2 when booting up the computer
2. Select 'Config', then 'Serial ATA (SATA)'
3. Change controller option to 'Compatibility' / 'IDE'
Jun 21, 2011 | IBM NetVista PC Desktop
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
First freeze, then boot slow, then boot "PBR 2 ...done, then disk read error Ctrl Alt Del to contine..., now no screen at boot up....fried???
Steps for solution
Mar 11, 2010 | Dell Inspiron 6000 Notebook
Start up gets to "Loading PBR for descriptor 2... done"
I suspect that the viruses had infected some of the files that windows needed to boot up. The moment you ran the Mcafee, the scanning might have deleted or quarantined those files. That is the reason you're having this Loading PBR message because it is now trying to boot from the network and not from the hard drive. You will need to repair windows using the CDs that came with the computer (the Operating system CD/DVD) and run CHKDSK /R at the screen where it says 'repair your computer using the command prompt". If this does not work, chances are, you may need to reinstall windows and everything and that all information in your hard drive will be wiped out.
Jan 03, 2010 | Computers & Internet
No disk to retore XP
Usually Dell will install the restore files on a hidden partition called D: when the computer comes from cold start press F12 multiple times there should be a black boot screen allowing you to select from a menu...
May 28, 2009 | Dell Computers & Internet
Loading PBR for descriptor 2...done
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron XPS M140 Notebook Logo
139 people viewed this question
Alun Cox
