Question about Gateway FPD1975W 19" LCD Monitor
How do I change the Language On my Gateway Monitor FPD1975W?
There is Chinese characters for letters on my side paneal
SOURCE: power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Posted on May 18, 2008
Bat1956
  • 585 Answers
SOURCE: my gateway monitor FPD1975W 19inch LCD won't turn
I have repaired similar FPD models. I have one of them on this very desk.
The GatewayFPDmodels develop problems after a couple or more years of use. Therepairsare fairly easy for the savvy technician. The power inverterboard inthe back of the monitor contains some capacitors, they may be470 and220 mfd or 680 mfd depending on when they were made, @ 10 16 or25volts, with a 105 deg. C temp rating. They go bad due to heatissuesand the currents they have to filter. Replacement of thecapacitorsusually restores operation. Use capacitorss of the sameratings as original for replacement.
Be advised, turning the monitor off when you are not using it will extend the life between these repairs.
Hope you find this helpful.
Posted on Apr 24, 2009
  • 555 Answers
SOURCE: Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Posted on Oct 09, 2009
SOURCE: my gateway FPD1975W 19 INCH LCD MONITOR DOEN'T
(thank you budmrtn) my monitor shut off..i went online looking for solutions gate way fpd1975w..i looked hard for about 2 hours..i found a common problem was with the power supply..(budmrtn) hit it on the head..i am not an electronic expert at all..i have a soldering gun..thats is..no testers..so i took the monitor apart and found the power supply was a seperate board..i took it out and looked at it and said hmm. do i throw the 180.00 monitor out or do i take a chance..i took the chance..i went to radio shack and bought 10 capacitors like (budmrtn) said i replaced them..if it did not work i was out 10 buck and i was going to throw it away..but well and behold..i replaced the capacitors..just the big ones not the round blue ones..and wala..new monitor..it worked..crazy i no..but it worked..and i have a 19 inch lcd that works and i was going to throw it away..if you need to know what i replaced email me and ill let you know..
Posted on Feb 01, 2010
benwabnick
  • 2404 Answers
SOURCE: Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Posted on Jun 02, 2010
Resetting lenovo tab 10 x103f comes up in chinese how do i hard reset in english?
When the tablet boots up and first shows Chinese, you 'should' be able to select a different language. I assume the language list is in Chinese, so here are the characters that represent English:
or
or
If neither of those character pairs is on the list, or you do not have the option to change the language, please send me a picture of the screen once it has finished booting up and is waiting for input.
Apr 20, 2017 | Lenovo Computers & Internet
How do I change language on Apple MP4 16gb multimedia player
1. Open Google Translate: https://translate.google.com/
2. Type "Settings" in the left text box on the Google Translate page.
3. On the right side next to the languages, click the little triangle that points down and choose "Chinese" to see the letters/symbols that match the lettering for the "Settings" on your device. Choose that option on your device.
4. Go back to Google Translate and type "Language" to see the letters/symbols that match the lettering for the "Language" on your device. Choose that option on your device.
5. Once you are in the language settings, you should be able to choose "English".
Oct 26, 2015 | Apple Audio Players & Recorders
Gateway FPD1975W Monitor Vertical lines in the right side of the screen
Open the unit back up and check the cable that goes from the control board to the LCD panel and make sure it is plugged in securely. If this cable is not connected all the way it can cause lines on the display. Also while you are inside the unit check the capacitors on the power supply board. The tops should be flat, if you have any with bulging tops then you need to replace all of the ones on the power supply board. This can also cause display issues if the power supply is not putting out the correct voltages because of bad capacitors.
Jul 17, 2012 | Gateway FPD1975W 19" LCD Monitor
I cant change the language of my laptop. All written in chinese character. I dont understand any words.
The buttons are available on the Language bar only if you have added multiple languages or multiple keyboard layouts in Regional and Language Options in Control Panel.
You can minimize the Language bar and switch between languages or keyboards using the icons on the taskbar
When entering text, you can use the keyboard, speech recognition, or handwriting recognition interchangeably without clicking a button.
The letters on the language button represent the active language. For example, EN stands for English.
May 09, 2011 | Computers & Internet
I purchased a mp4 media player in hong kong. Please can you tell me how to change the language from chinese to english
This forum has listed the Chinese names for the menu options you are looking for (I could not directly paste the Chinese characters here). Clicking on them should allow you to change the player's language.
Mar 05, 2011 | Audio Players & Recorders
This is the third time I,m trying to get an answewr to this problem . I followed the sugestion the first time and it didn,t work. Let's try again. I have a gateway computer in the upper right corner in a...
If you change the Windows "wallpaper", does that text go away?
If you connect the LCD monitor to a different laptop/desktop, does the text still appear?
If you connect a different LCD monitor to your computer, does the text still display?
Sep 17, 2010 | Gateway FPD1975W 19" LCD Monitor
After the Windows XP progress bar is done, the monitor goes to a screensaver, its a black screen with a blue block moving around the screen, with some kind of chinese lettering. At this point I can't...
First,turn the power off on the screen. & unplug the screen from the computer.After it's disconnected turn it on. This is to see if this screen saver thing is the monitor or the pc doing it.
The Monitor, if working correctly will say "No Signal". ONLY.
You should be able to get to the menu here.
If the Screen saver thing is only present when connected to the PC then its not the monitor but more than likely a problem with Windows XP configuration.
Here is your user manual:
http://support.gateway.com/s/Manuals/Monitors/8511446.pdf
If you can set up your monitor now, do so. Make sure the language part of it is set to English settings.
Sep 14, 2010 | Gateway FPD1975W 19" LCD Monitor
Treo 650 change from chinese characters to English
try doing a hard reset and it should give you language options after that, if its not giving you language options,the rom might be chinese only,you need to flash the rom to an english version.
Dec 08, 2008 | Palm Treo 650 Handheld
I type in one thing and another character shows up on the screen
It could be virus or you can check and make some change in Language setting form control panel.
Nov 12, 2008 | Gateway MT3705 Notebook
Gateway FPD1975W 19" LCD Monitor Logo
96 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
