Question about Honeywell Programmable Thermostat Heater
My daughters honeywell ch/hw digital control resets to zero
The hw/ch control has the hot water and central heating on/off times set but the control resets itself and the digital display shows zero. Is it broken or am I doing something wrong?
    Problem Solver:
  • 16 Answers
Have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Posted on Aug 17, 2009
Hw and ch not coming on auto , will come on if reset but following day will not come on again until reset , there is no red light on , on the time guard does this have any thing to do with it?
Hw & ch in my vocabulary means Hot Water & Chiller. I have never seen this on a thermostat. I'm also assuming by time guard, your saying time delay. The time delay only goes into effect if there is a power interruption.
Dec 02, 2013 | Honeywell Programmable Thermostat Heater
Siemens rwb29 controller doesn't work properly. central heating comes up only when you select hot water, but not on its own
This happens to my rwb29 from time to time. You can try switching off the power to the controller for a couple of minutes with CH thermostat and CH programs set off. Or you can press the little reset button to the bottom right of the LCD screen. After 1 or 2 attempts these steps usually restore the independent control on my unit.
Nov 05, 2012 | Siemens RWB29
Heating and hot worker work separately but not together
If this a honeywell valve you may need to change the motor in side the valve , sounds like its lost some of it power to move the inside of the valve to y postion .
Nov 04, 2012 | Honeywell Programmable Thermostat Heater
How do i set the heating/hot water timer on the LP112-24 acl controler ?
The instructions are available here: http://www.draytoncontrols.co.uk/Complete_LP_Installation_User_Instructions.aspx I hope I have been of help but please do not hesitate to ask if you have any further questions. Set the central heating Press the YES button, and the display will ask 'SET CH PROG?'. Press YES and you'll see ON1, the start of your first central heating period. Adjust it in 1-minute steps using the - and + buttons. If the - and + buttons are held down, the time changes in 10-minute steps. Press SET?, and you'll see OFF1, the end of your first central heating period. Adjust this in the same way, press SET?, then repeat the procedure for ON2, OFF2, ON3 and OFF3. Set the hot water When you press SET? after setting OFF3 for the central heating, the display will ask 'SET HW PROG?'. Press YES, then set your times in the same way. Remember, in this mode you can have different times to your central heating if you wish. When you press SET? after setting OFF3 for the hot water, the programmer will return to normal operation.
Feb 19, 2011 | Heating & Cooling
My central heating pump does not switch off when the acl lifestyle model lp722 central heating timer switches both the hot water and c/h off. pump keeps running through the night
if you can turn off the hw and ch off , to the off postion and it shuts off then the acl lifestyle could needreplacing mine did the same on ch only so changed mine , or check the divtervalve is working and not stuck in the open postion , try turning hw on and off only then the ch see if valve works
Jan 08, 2011 | Heating & Cooling
I have a Honeywell ST499A/ST699B "Central Heating Microelectronic Time Controller" managing the operation of my house boiler. The time controls are set properly. PROBLEM: If I want either hot water or...
I have an old Honeywell ST499A/ST699B thermostat. It still works OK but when we have a power cut I have to re-programme everything. Presumably this is because the battery needs replacing. I cannot find a way of opening the control box to get into the unit to replace the battery and in any case I’m not sure if the battery is renewable?
Oct 12, 2009 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Central haeting ok but no hot water
If the valve runs at other times, the valve is OK. you have a relay somewhere that is not sending signal to the valve when in that mode.
Trace down all the relays for that cycle and check voltage going int, coming out, and to see if the coil is enrgised.
Jan 01, 2009 | Heating & Cooling
Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
May 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
352 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
