Motor will not stop afetr wash cycles end
Service tech said the board needed to be replaced for $300
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 10, 2012
  • grayson foster Nov 14, 2012
    frigidare dishwasher model gld4355rfs0
SOURCE: Fisher & Paykal washing machine, Mod:GHL10US
I have a Fisher Paykal model GWL11 washer. After doing a successful load my wife tried another 15 minuts later and the power won't go on. There's power at the plug and she also unpluged the machine and tried later but no power
Posted on Jun 16, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool LSR7133KQ0 no pumpout, rinse, or spin.
NO...the problem you are describing are the typical symptoms of a lid switch malfunction. The lid switch shuts the washer off when you open the lid while the drum is spinning. This is a safety feature to prevent injury from moving parts if you decide to add a garment or stick your hands in the tub for some reason while it is in operation. On some model Whirpool's the washer WILL work initially for the wash cycle, then stop when it gets to the rinse cycle. I would recommend you check your lid switch to make it is not loose or broken. Your washer is also equipped with a lid strike (a small plastic piece on the lid that activates the switch) make sure it is not broken off or missing. This will give the same symptoms of a broken lid switch.
If you require a replacement switch, they can be ordered on line at searspartsdirect.com, or you can go to your nearest appliance parts retailer. The part number for the switch is 3949247. The lid strike (if required) is part number 358684. If you need instructions on how to replace the lid switch, you can use this link if you like:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
I don't know how savvy you are, so I thought I would add the instructions just in case. I hope you find all this information helpful. Let me know if you require additional assistance.
Posted on Sep 25, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
SOURCE: Kenmore washer "warm" wash cycle not above room temperature
aaa
Posted on Jul 09, 2009
Beko WMB714422 .... washing cycle stops after 5 mins of the cycle and shows 'end'. Cant get it to do a full cycle. Any ideas ?
This is most likely an issue with the motor, causing confusion to the electronics, sometimes you can replace the motor and remedy the issue but I have had a couple of occasions with Beko machines where the motor fault caused damage to the control board
Jun 12, 2016 | Beko Washing Machines
F&P washer stops spin cycle
You will need to check the out of balance switch under the motor controller board for corrosion and replace if faulty.
May 24, 2013 | Fisher and Paykel Washing Machines
Slow spin
see this causes and fix it. God bless you
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy to check and replace.
Door Switch
This can cause the washer to not agitate or go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Sep 30, 2012 | Crosley CW6000 Front Load Washer
Flashing red light tap
see the causes and fix it. God bless you
oor Switch
This can cause the washer to agitate but not go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Sep 22, 2012 | Hotpoint WMA64 Front Load Washer
Front loader maytag stop in middle cycle give error F25
Remove your service panel and look for your tech sheet inside a jacket in the inside of the service panel. An F-25 is usually a broken wire between the main control and the motor control.
Oct 09, 2011 | Washing Machines
LG frontloader runs thru majority cycle & towards the end it stops & flashes "LE" code. I have replaced Hall sensor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error, but it is possible to separate the working from the non-working, just by following a process. The reason this particular unit has been on the injured list for so long is the first tech never followed a trouble shooting process to ensure the parts being replaced had actually failed.
Nov 26, 2010 | LG WM-1832C Front Load Washer
Washing machine does not finish complete cycle
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Jul 06, 2009 | Samsung WF203ANW Front Load Washer
Wont spin at end of any cycle
I am a service technician in grants pass oregon and i had the same problem. It told me to replace the board too. I replaced the main boad, Motor control board, door switch and cleaned all the hoses and it still didnt fix it. I had 3 other service technicians look at it ( one from sears ) And nobody could figure it out.
Feb 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
I have an equator washer/dryer combo. It seems to have a few problems. The washer doesn't spin during the spin cycle, although it spins during the rest of the wash cycle. The pump is making a weird...
I have one of these things, too, an EZ 3612 CEE. I've replaced the pump on mine, but I am in no way an appliance technician. However, your problem seems like an electronics problem to me and the service people I've spoke to about this machine have told me that the main circuit boards in these machines fail regularly. That has yet to happen to me. I would suggest calling the equator service number. You'll be connected to some technician in India, almost certainly. But my experience with these guys has been great. They have VERY patiently talked me through a couple of different diagnostic procedures and solved some problems. Don't have the phone # just now but you can google equator appliance and get it.
Jun 23, 2008 | Equator Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
