Question about Water Heaters
Microgenus 24 he error code a01 - Water Heaters
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Indoor tankless 74-pvn. power went off and has returned. get error code 24 when try to power on
Open following links for Rheem troubleshooting resources, including Rheem chat, error codes, and possible manual.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error codes are considered start-point for troubleshoot.
Error code 24 is malfunction of operational switch: press max or min button on PC board to reset, -or- replace PC board.
Max-min button is sometimes located above dip switches, and can be 1 button that is rotated with screwdriver or 2 separate buttons. Look at wiring diagram in manual that came with product.
Fix most tankless problems yourself, same day, for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 14, 2011 | Rheem Tankless Hot Water Heater...
I am getting a C2 11 code on my eco sense tankless water heater. There is also a flashing 24, any ideas? Thanks
Multiple error codes can mean PC board failure.
C2 11 is no ignition.
Error 24 is malfunction of operational switch: "press max or mim button on PC board, or replace PC board." On some models, max and mim button can be located just above dip switches, and rotates with screwdriver. See diagram in manual.
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Aug 10, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Error code e2 on Rheem tankless water heater
e2 is not shown among common error codes:
Error e2 might be: Brownout condition or too low of voltage to thermostat. Double check wiring and check for 24 vac between R and C. E2 will clear 15 sec after proper voltage is restored.
Before calling service technician, open following link for Rheem troubleshoot resources including Rheem chat and typical generic manuals and common error codes:
Model number and serial number are required for Rheem contact, and then they tell you what error code means without saying how to fix it, and then tell you to call service technician.
Tankless water heater manuals each say to have qualified technician perform yearly service. Most causes for common error codes are covered by yearly service.
Yearly service is fairly standard in the HVAC and water heater industry with advancement of high-tech 'energy' saving appliances. Of course all costs are energy, and the service call probably costs more that the 'energy' saved by energy-saving appliance. But with high tech stuff like tankless, it is good to have a reliable service guy who knows your machine.
http://waterheatertimer.org/images/Tankless-wiring-1200.jpg
Jul 27, 2011 | Rheem Tankless Hot Water Heater...
Rheem Integrity 24 Has Error LO79 can someone tell
79 is fan motor current fault or circuit board you will have contact rheem
Jun 07, 2010 | Rheem Tankless Hot Water Heater...
Not able to top up water level on my ariston microgenus 20 MFFI
Julie... I need more information to solve your problem. Such as make and model of your heater.
Ray
Nov 14, 2008 | Water Heaters
Ariston A01 fault combi boiler
its not definately the pcb. change the detection sensor first( £3.20p). if this doesnt fix a01 fault then change the main pcb(£145).
Oct 29, 2008 | Water Heaters
Water Heaters Logo
23 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
