Question about General Electric PVM2070DMWW 1100 Watts Microwave Oven
Pvm2070 will a pvm2070 fit on a jvm1650 mount
  • General Master
  • 9,098 Answers
GE Customer Service is here.
They should be able to tell you which models will be "drop-in" replacements for a JVM1650.
Posted on Jan 09, 2009
How do you replace the fuse in ge pvm2070
You should first check the outlet with a toaster or hair dryer to be sure it's working under a load.
Then you should test the fuse then the TCOs if the fuse is good.
There is a technical sheet hidden behind the grille or controls.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 19, 2013 | General Electric PVM2070 1100 Watts...
My GE Spacemaker microwave - control buttons seem confused. When I press one of the buttons, either nothing happens or it goes to the wrong screen. What is up?
On the JVM2070- and PVM2070-series microwaves, GE does not make service information or separate parts available.
So when you have an error with the controller that does not involve the smart board (and this error does not) then you have to order the control panel subassembly, which on your model (PVM2070SM1SS) is part number WB07X11143 and you can get it from the Pros here for $477.83 (subject to change).
It's very expensive but it's actually simple to replace that part yourself.
You would remove the control panel assembly as shown in our video here, then remove your smart board and attach it to the new control panel subassembly.
Some connectors on the relays have a lock:
If it's under warranty or GE Customer Service would give you a break on the the part cost, that would be a big plus for you.
Aug 22, 2012 | Microwave Ovens
Ge pvm2070 shut off and now will not come on
My PVM2070 Spacemaker Microwave quit working & its DEAD. I checked circuit braker, unplugged unit, checked power is ok, open/shut door, pushed very sensor buttons; its DEAD. Help??
Nov 09, 2009 | GE PVM2070SMSS Microwave Oven
Ge jvm1653 bh01 wall mounting
Aug 23, 2008 | GE JVM1650 1000 Watts Microwave Oven
Can I reuse mounting plate for new microwave?
i always reccomend to my custs that they stay with the same brand for same mounting bracket, dontreally know a way to verify other hten removing hte old micr first and then before purchasing ask to open box to check
Mar 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm 1650 burned one of the mounting brackets
The mounting brackets don't have electricity in them, it has to be an internal short in the oven. It should be taken down and opened up to determine what happened. If the damage is too severe the oven probably would have to be replaced. I would take it to a repair center and get it diagnosed and see if it is something simple that won't cost a lot of money.
Dec 25, 2007 | GE JVM1650 1000 Watts Microwave Oven
SpacemakerXl Microwave Oven JVM1650/1651
The magnetron may be failing or overheating.
There is a known issue with many GE models.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | GE JVM1650 1000 Watts Microwave Oven
JVM1650 not heating
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Please write back with more details if you need further help.
Dec 02, 2007 | GE JVM1650 1000 Watts Microwave Oven
General Electric PVM2070DMWW 1100 Watts Microwave Oven Logo
137 people viewed this question
Top General Microwave Ovens Experts
William Miller
William Miller
ken skalski
Steve Mason
Are you a General Microwave Oven Expert? Answer questions, earn points and help others
