Question about Kenmore 22422 Top Load Washer
There is a leak from the pump of my kenmore top loading 20722990
Where can I get the replacement part and how soon
    President:
  • 2,692 Answers
If you type in "kenmore washer parts" you get 10 pages of hits on where to get parts. If you contact a local appliance parts dealer,I am sure he may have one on the shelf, it is such a common item.
Posted on Jan 05, 2009
I have a kenmore 3 speed washer mod # 20722990. The problem is when in the spin cycle the water will not drain completly and the spin is very slow. The agitation in the wash cycle is good. Thank you for...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
p'';
Mar 05, 2011 | Kenmore Washing Machines
Kenmore 80 leaks in
yip no worries pump is the same as phillips/whirlpool 5min job only 2 clips
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series. Leaking from front under washer. Can hear standing water under agitator/basin
Usually with this situation its a pump leaking, does it leak mostly during use.if you lean appliance back, should be able to take a peak underneath at pump. will just need to be replaced if leaking.
Jun 08, 2009 | Kenmore 22422 Top Load Washer
Kenmore 20722990 series 70 will not drain
I have the same problem right now. I found a dime in the discharge but it still does it. I am going at it from the front side of the pump now. I need disassembly instructions for the upper sections to get to it. It was really nasty dirty and stinks.
Mar 18, 2009 | Kenmore 20722
Water leak
Replace the water pump. They will leak.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Top load kenmore 110
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
This is commonly caused by a leaking water pump, or the hoses attached to the pump. The following link explains how to access the interior of the washer to inspect for leaks:
http://www.fixya.com/support/r397092-replacing_water_pump
This link explains how to replace the water pump if that is the case. Keep in mind, these pumps are sealed units and are not serviceable. If the pump is leaking, or not functioning, it needs to be replaced. in addition, double check all hose connections to the pump (there usually two hoses) and make sure there are no cracks or holes. Make sure the hose clamps are secured properly. I hope this helps you. Let me know if you require additional assistance.
Oct 21, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer top load heavy duty 80 fluid leaking
It's rusty Water probably the water pump housing is cracked might be replaceable need to take a look at it or call Kenmore for the part
Apr 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore model # 20722990
It sounds more like the timer motor is stopping. There mght be something binding or a dead spot on the motor.The next time it does that, advance the timer slightly a few times and see if it then advances on it's own Check all the wires, too. Take the timer assembly out and flush it several times with alcohol or plastic safe electronics cleaner while operating the timer (engaged) several times.
Mar 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
