Question about Samsung SyncMaster 2220WM 22" LCD Monitor
Hi,I got some problem with my Samsung Syncmaster E2220 monitor....The monitor look like still not connected to CPU as it still searching for it source although i attach both wires (DVI &VGA)correct to it place...What ihave to do ? Thanks
Riziel
  • 116 Answers
SOURCE: Samsung Syncmaster 245BW, can't get it up and running !
Most of the time when this happens it is due to a bad monitor, if you have another pc try to hook this monitor up to that one to see if it actually works, these monitors sometimes get damaged during shipment!
Posted on Nov 26, 2007
tolexade
  • 81 Answers
SOURCE: Samsung syncmaster 551v
you dont have problem with your monitor, check your cpu very well am very sure you have problems with your system board
Posted on Jul 17, 2009
bob_computer
  • 3153 Answers
SOURCE: Switching between sources on a Samsung SyncMaster 2033
A computer monitor is not truly designed for the purpose you have in mind
As far as the VGA connector is concerned it is still meant for connection to a COMPUTER
The same for the HDMI.
We are seeing this problem more and more as people look at the price rather than its intended use.
A TV is a TV.
Yes you can hook up some external components as you have done but the only way i have seen it work is by the following and is not 100% guaranteed to work in all situations.
Turn off the device you no longer wish to watch using the remote
Turn off the monitor
Turn on the device you wish to watch using its remote
Turn on the monitor.
The only reason that method works at all is that some monitors auto detect which input actually has a signal on it.
You can buy switching boxes also if you don't mind adding to the amount of cables etc. Remote switches may cost quite a bit more than a manual one.
This is the ONLY answer I can give you. Your monitor does not have a remote and the reason for that is that it is not a TV.
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FIXYA.
Thank you
Posted on Nov 30, 2009
  • 109 Answers
SOURCE: VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Posted on May 17, 2010
CreativeTECH
  • 1719 Answers
SOURCE: samsung syncmaster 2033sw monitor, till
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Posted on Nov 15, 2010
Samsung syncmaster 245bw powers on but there is no display.
check your rgb chord found at the back of your monitor, i think it is color blue chord that connects through cpu and monitor..push it tight and it will display again..
i hope it can help you
Jul 25, 2011 | Samsung SyncMaster 245BW Monitor
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
My Samsung syncmaster 730a monitor wont come on. the green light is solid but screen is black. could i have done something or might it have gone bad?
Hi friend,
You need you check your display cable. it should be connected in your CPU. sometime cable lose in CPU..then monitor not given any display ...
Dec 20, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Hi, my monitor does not display anything but the lid light just keep blinking.
You should check your display cable from CPU to Monitor. If it just blinking then problem with you connection bitween CPU and Monitor So just check and keep enjoy.
Nov 11, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
No driver
samsung website have not this driver :(
you can download free SyncMaster 740N driver from :
http://uploading.com/files/71958d12/SyncMaster%2B740N%2Bdriver.rar/
Aug 12, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Jul 17, 2009 | Samsung SyncMaster 151 N 15" LCD Monitor
Samsung SyncMaster 2220WM 22" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
