Question about Polti Vaporetto 2400 Canister Steam Vacuum
I have been given a Polti 2400 Vaporetto Steam Cleaner and need advice on whether you have to empty a bag or filter
  • Polti Master
  • 18,391 Answers
5 Suggested Answers
SOURCE: Polti Vaporetto
Dear Terena
Had the same problem with a polti vaporetto 1500 ( vtt 1500 ) after butchering the big valve on the top I realised that the problem was that there was a blockage in the black pipe that comes from the machine to the trigger, the pipe that carries the steam in other words, so I got a piece of wire ( brake cable form a bike shop ) long enough to go at least half way down the pipe and then I pushed the wire down the hole at the trigger end and then from the other end that joins to the polti and hey presto the blockage was gone and the machine works fine again. If you use the machine again after you have cleared the blockage from the pipe you should be able to remove the valve from the top remeber that the water is now steam so it is very hot and will burn you so be carefull when opening the valve when hot I think that you will have to open it when it is warm not hot as what has happened is that scale has got in the threads of the valve and sealed it, so if you get it undone ( try pushing it down hard as you turn it Whilst it is warm only not hot ) then get some kettle descaler and put some in a bowl of hot water and put the valve threaded end in the descaler for 10 minutes to get rid of the scale and in the mean time put some descaler around the threads on the polti where the valve goes this will allow the valve to screw back on easily and you will be back to normal use again remember to keep the valve screw threads free of scale in the future I have only just reallised this so dont feel alone.
Pete
Posted on Dec 04, 2007
  • 17 Answers
SOURCE: NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Posted on Mar 11, 2008
  • 389 Answers
SOURCE: How do I undo the torx screws that hold the Polti
With a torx screwdriver! There's nothing special about these screws except the shape of the hole in the head. Commonest size in small domestic machines is T15.
Posted on Oct 15, 2009
Ranglo
  • 1194 Answers
SOURCE: lost instructions for vaporetto polti 2400
Download instruction manual for Vaporetto 2400
Good Luck
Rating the solution is highly appreciated
Posted on May 31, 2010
Does the Polti Vapoetto **** / vacuum up dirt and do you have to empty this
no it DOES NOT S-CK UP DIRT IT'S ONLY FOR STEAM CLEANING
Nov 10, 2012 | Polti Vaporetto 2400 Canister Steam Vacuum
Lost instructions for vaporetto polti 2400
Good Luck
May 31, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
How do I undo the torx screws that hold the Polti 2400 Steam Cleaner (Polti Vaporetto 2400) together? There is an electrical fault and I will have to strip it down to investigate.The house RCD trips when...
Oct 15, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporetta - steam escaping from valve
Are you sure it is not escaping from the top? if so replace top.I have had this myself
May 11, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400 Canister Steam Vacuum Logo
198 people viewed this question
Top Polti Vacuums Experts
cwradio73
Kolbrun...
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
