Question about Toshiba e-Studio 232 Black and White Copier
Toshiba e-Studio 233 error code E030 - Toshiba e-Studio 232 Black and White Copier
SOURCE: Error code in E studio 150
Hello! I did it and it worked perfectly.
I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
Posted on Feb 20, 2008
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
  • 628 Answers
SOURCE: How to determine what error codes for failure on Toshiba E-studio
Press "Clear+8" and u will see the error code.
Posted on Mar 02, 2009
  • 628 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
  • 46 Answers
SOURCE: ''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Posted on Nov 04, 2009
Error code e030
Code E030 Description Power-ON jam: The paper is remaining on the paper transport path when power is turned ON.
Aug 09, 2015 | Toshiba E-Studio 255 Digital Copier...
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
How to fix E030 error
Error E030 sensor problem, check the sensore paper feeders,
sensore check the registration proseder cleaning them, or replace them
Feb 23, 2015 | Toshiba E-Studio 282 estudio 282
Paper misfeed error code E030
Apr 09, 2014 | Toshiba E Studio 2330C
Error e030 copier toshiba 202L
E030 indicates Paper remaining inside the equipment at power-ON.
If no paper is found, probably the actuator/sensor is faulty. Kindly perform input test on following sensors:
Exit sensor 03-[FAX]ON/[2]/[B
Registration sensor 03-[FAX]ON/[2]/[A]
Upper drawer feed sensor 03-[FAX]OFF/[6]/[E]
Aug 28, 2012 | Toshiba e-Studio 202L Copier
Toshiba 3511 e030
[E030] Power-ON paper jam(power is turned on while there is still paper jammed inside)
Open the cover of the unit/area whose picture is flashing on the control panel.
Is there any paper on the transport path?
YES - Remove the paper.
NO - Is the sensor in the jamming area working?
NO -1) Check if the connector of the sensor is disconnected.
2) Check if any of the connectors on the LGC board is disconnected.
3) Check if the connector pins are disconnected or the harnesses are open circuited.
4) Check if the conductor pattern on the LGC board is short circuited or open circuited.
5) Replace the sensor.
6) Replace the LGC board.
J
May 19, 2012 | Toshiba Office Equipment & Supplies
Error code e030 for toshiba e studio 351c
try to clean any hard load at the main motor by fixing developer unit drive or drum drive and the gears unit below the main moter
Mar 04, 2012 | Office Equipment & Supplies
I have a toshiba e-Studio 351c show E030 , i was remove the paper jammed but the machine not work and still show E030
clear very well the paper path especially if there is bridge who trasfer the paper to the finisher and check the sensor inside it or check if there is any load at the main motor
Nov 30, 2011 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 232 Black and White Copier Logo
400 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
