GE Front loading washer
Can you tell me how to remove the front panel under the door? I've removed the three screws, but still can't get it off. THanks so much.
  • 15,935 Answers
Thats it. Take a putty knife between the panel and body to separate.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
Wcvh6800j1ww leaking under soap dispenser
Three screws at the back of cover, three screws at the front, push the cover back and you can remove it. 1 screw at the front of the soap drawer and two more on the dispenser and you can lift the whole unit up.
Sep 24, 2012 | GE WCVH6260F Front Load Washer
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
Duet GHW9150P Front Load Washer: how do we open a whirlpool front loading machine w...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
Mt front load duet whirlpool is locked full of water
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading washer will not agitate and now I can not get the door to unlock
Jul 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My GE front load washer (wcvh6800) starts but won't complete even the first part of the cycle - shuts itself off with the door locked. Any ideas appreciated.
The timer is failed.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Jul 11, 2009 | GE WSXH208A Front Load Washer
Mildew in ge front load washer
Try two things: Add several cups bleach to the tub and run it a complete cycle. When not in use, leave the door open so it will air out.
Jun 04, 2009 | GE WBVH6240F Front Load Washer
Ge washer
remove top cover by 3 screws on rear then 3 screws in plastic control panel back. remove screws holding console on, lift up to remove, screw in dispenser area as well. remove lower kick panel and lower front panel screws. remove door lock screws and wire clip around boot. remove 2 upper front panel screws. there is another wire clip around boot at tub.
Apr 22, 2009 | GE WBVH6240F Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
