Question about Bosch 24 in. SHU43 Built-in Dishwasher
Water in not coming....
Water line is good, control panel is good. when i do the test, it drains... problem: When starting the Wash cycle, water is not coming inside the washer... NO WATER.
  • 175 Answers
If you knwo the water line to be good, take off the toe kick plate below and find the inlet valve. It will have a connection with 2 wires on it. Pull the connection off and put a volt meter on it. Start a new cycle, and within a minute or 2 you should start reading 120 volts (or close to that) if you get voltage from the 2 wires, you have a bad or plugged fill valve. If you dont then you have bad wiring in the dishwasher, water lying in the bottom of the dishwasher, or a bad control board. Hope this helps!
Posted on Jun 18, 2007
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
How do i run a diagnostic test on a frigidaire mod. gltf2070dso?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on :http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Sep 04, 2014 | Washing Machines
How to stop the water?
Not knowing what brand / model you have makes it difficult however, the basic symptoms of a water problem are; If the water keeps coming into the machine with the power off and the tap on, it will be a valve fault. If the water keeps coming in with power on and on a wash cycle, its likely to be a fault with the pressure switch, pressure tube (Split or hanging off) or an electronic failure of the control board.Lastly, check the drain hose. If the end of the hose is lower than the water level of the machine, it is possible for the machine to start syphoning itself. Espe3cially just after the first pump out (Start of Rinse cycle) Make sure the machine is actually pumping water out. If it cant pump out, the machine may try to refill but it is already still full from last wash , causing the error code to flash. Check for pump jamming up with foreign objects, or hoses blocked with a sock, lint etc.. Sorry but cant help much more than this.
Sep 02, 2014 | Washing Machines
Wash Cycle will not start; ADD GARMENT and DOOR LOCKED lights on.
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
Feb 01, 2014 | Kenmore HE2 Washing Machines
Whirlpool wfs 1071bd. Washing machine starts , drain works , then start/pause indicator lamp flashes. Wash light is on. No other lights on. Taps are on , and nothing is happening. Any ideas?
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Mar 23, 2013 | Washing Machines
F/paykell not agitating
Feb 07, 2013 | Washing Machines
Bosch classixx washing machine over fills, stops for 5 mins,drains water and stuck on rinse without doing the wash cycle. it spins when spin cycle is manually selected.
Jan 25, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Stuck in wash cycle
Jan 21, 2013 | Whirlpool LHW0050PQ Front Load Washer
Washer won't agitate in wash cycle
Jan 19, 2013 | GE Profile WPRE6100G Top Load Washer
Put new bearings in put a wash on then 45min of end of wash it stoped and said start on the panel is it the circuit board
Now since the washer worked for 45 mintues it is possible that when the unit was removed some connector had come loose on the controller . so please check on the panel , check on the control panel and the wiring before a decision can be confirmed.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Thank you for using fixya.
Aug 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Bosch 24 in. SHU43 Built-in Dishwasher Logo
60 people viewed this question
Top Bosch Dishwashers Experts
jimorris77
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
