Question about Acer P221W LCD Monitor
Acer p221w blue light flashing wont turn on or off
Replaced the capacitors but still have the same problem. both boarsd look ok ( power & video ). any ideas
  • michael Nov 09, 2012
    it does this when conected to the computer or just plug in by itself. have an extrs moniter on the computer and it works fine.
A vertical line in the middle of my Acer P221w monitor
dead pixels?? although im told dead pixels are red.
Feb 16, 2013 | Acer Computers & Internet
My sanyo tv odel ce37ld33-B turns itself off and blue light flashes when i turn it back on
you have bulged capacitors on the power supply board that need to be replace in order to fix the problem
Nov 03, 2012 | Sanyo Televison & Video
Acer P221W turns off without warning
tried with unplugged and re plugged doesn't resume in normal ?.ok check loose connection in the power adapter.if still doesn't resolved the problem, at this time you will need to check the power supply if it is working.you can use a digital tester or an analog to make a voltage checking.
Oct 07, 2012 | BenQ FP71G 17" LCD Monitor
Power supply light keeps flashing and the unit wont turn on
The reason the console is not turning on but flashing the power light is because there is a problem in the unit.
First try to dismantle the console and tighten every connection, then you assess the power panel for any bad capacitors, if there is any bad capacitor, have it replaced, by carefully turning the board to the back and melting off the capacitors tip and replacing it with a new one.
After doing that, reassemble the console together and try to turn it on, and you will be surprised that it will work perfectly.
Take care and good luck
Oct 23, 2010 | Microsoft Xbox 360 Console
LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | LG 26LG30 26 in. LCD TV
Philips 42PF9967/10 blue light comes on the here a clicking of the relay then clicks off again and the blue light stays on and the red light at left of flashes
Your TV must have bad capacitors on the power supply board.
The tops of the capacitors will be domed/swollen.
Replacing the capacitors will fix the problem
when you take the back off, locate the plug wires from where they come into the back of the TV follow them up and it will end in the control board. search for the capacitor that would have bulged or swelled. This was not just take a quick look, it would be so slight that it wasn't even really apparent until we scrutinized each one.
Replacing this Capacitor would solve your problem
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 17, 2009 | Computers & Internet
Screen resolution for Acer P221W
1680x1050.
It also depends on the video card how high the resolution can go.
That's the max resolution though.
Here's the complete specs for your monitor.
Have a good day!
Jul 18, 2009 | Acer AL1916W 19" LCD Monitor
ACER P221W No display and power light blinking
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If the monitor does not have any bad caps then I would be that when the video card died it sent a spike to the monitor and killed the driver board. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 28, 2009 | Acer P221W LCD Monitor
I have a Pt-56hx41pf Panasonic and when I turn it on it trips off with a red light next to the led power button flashing. When I turn it on again it wont come on. If I unplug it the tv would come on to...
CK your hori output ,& blue capacitor 1200pf 2000v see if it is burt if these are OK Then Replace Both of your STKsThey are your convergence ICs but they also cao affect power.They are big black chips with STK on them IF they are 392-110s upgrade to 180s- if they are 020s use 040s if 560or 570 use that number for part to replace there is no upgrade and big differents in 560s-570s.If you need anymore help let me know. Resolder all poor connections you find.
Dec 23, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Acer P221W LCD Monitor Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
