Question about LG LFX28978
Lfx28978 does not cool - LG LFX28978
    Top Expert:
  • LG Master
  • 9,472 Answers
See other post. Replace the control board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 10, 2012
I have an LG French door refrigerator Model LFX28978 ST/00. I noticed that there is ice in the ice tray but it is not dumping it.I turned it off and on and it moves freely, but does not dump the ice.
Sorry to tell you that LG makes the worst refrigerators of all time. The control panels have CONSTANT problems. I suggest you buy a home warranty that covers refrigerators.I had the big 31 CF Kenmore (made by LG). Sears came out THIRTEEN times trying fix it. They replaced the coils twice, the control panel twice and the refrigerant-line fluid filter 3 times. Finally they gave me $1000 to throw it away.
AS A WARNING TO SHOPPERS!!!!!!! You should stay away from high efficiency refrigerators!! They gain that efficiency by reducing the cooling capacity. The walls of heat exchanges are much thinner, leading to leaks. Ask any fridge repairman. All this leads to breakdowns after only a few years of service, because they are so fragile..
May 15, 2017 | LG Refrigerators
Why does water leak out from the bottom of the freezer drawer.
Water supply tube for the ice maker and drink dispenser is leaking somewhere.
Mar 17, 2015 | LG LFX28978
Water and Ice taste does not taste good . Filter has been replaced
mold in the tubes... you need to run a little bleach through it.. not sure how you will do that one
Sep 02, 2014 | LG LFX28978 27.6 cu. ft. French Door...
How to remove the drip pan
As far as I know you don't remove it. Check the drain isn't blocked and the best way to empty the water is by using a water vacuum
Jan 05, 2014 | LG LFX28978 (27.6 cu. ft.) Bottom Freezer...
LG lfx28978 Bottom Freezer cooling, but refrigerator section warm; no ice or frost build up anywhere. Started after an eight hour power failure. Also, fan located behind the unit on the lower right doesn't...
Melissa I think you hit the nail on the head! If it was running great before power outage, and problems started after! Power Surge sounds correct to me! below is a link for the service manual! As for board, sounds likely! Check the board for burnt fuses, I think there is 2. Sorry i can't help You more! Good luck!
LG LFX28978 series Service Manual Table Of Contents
Jul 14, 2017 | LG Refrigerators
The frig and freezer of my LG LFX28978 is not cooling at all. iT Appears the the compressor shuts off & does not come back on until the unit is unplugged and then plugged back in
You will need to replace the control board. The board controls the controls the compressor and it is not allowing it to kick back on after the unit has cooled. Here is the board to order.
Nov 10, 2012 | LG LFX28978
MFL62184410 fridge has a sour smell
Try using an open box of Arm and Hammer baking soda and let it stay in there for awhile. It may absorb the odor.
Dec 02, 2011 | LG LFX28978 (27.6 cu. ft.) Bottom Freezer...
We just had the regrigerator installed today. It was cooling and then we put the food back in and shut the doors and the readout now on the display where the temperature is says ER and CF. The water does...
If the unit was just installed you would call for service. Error Code Er CF -The unit will receive signals from the BLDC fan motor in the freezer compartment during normal operation. If more than 65 seconds pass without a signal from the fan motor, an "Er CF" error message will be displayed. The Cooling Motor Error is usually an indication of a faulty fan motor or loose leads. Customer service should be contacted immediately. IF you have any further questions message me back Thanks Rick
Sep 08, 2011 | LG LFX28978
How can i remove the door with the water line. I need to get it in my house
TAKE OFF COVERS ON THE HINGES- U WILL FIND ONE HAS THE WATER LINE THERE IS A JOINER IN THE LINE, YOU PUSH THE 2 HOSES TOGETHER IN TO THE JOINER AND RELEASE THE PRESSURE TO TAKE THE HOSES OUT AGAIN. THERE IS ALSO A MULTIPLUG TO DICONECT THE WIREING TO THE DOOR- UNPLUG IT.
2/3 SCREW THRU THE HINGE WILL ALLOW YOU TO LIFT THE HINGE AND THEN LIFT OFF THE DOOR
tHE WATER LINE MAY COME THRU THE BOTTOM HINGE-
Feb 27, 2011 | LG LFX28978
LG LFX28978 Logo
60 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
