Question about Select Products SP33D Barnes Diaphragm Sump Pump 1/3 HP
Diaphramg switch is oozing black liquid, is this a problem?
Does the oozing of black fluid from the plug in portion of the switch mean that the diaphramg switch needs to be replaced?
  • Joel Wiedeman May 11, 2010
    Can you get the pump to run at all? Even just by pluging in the motor? If you can I would suggest replacing the switch. Not worth the risk...
  • 332 Answers
There should be no fluids comming out,, you may just want to change the pump,,
Posted on Jun 23, 2009
  • gary miller
    gary miller Jun 30, 2009
    no you will need a new pump the casing is cracked and leaking the oil out of it,, it is supposed to be a sealed system, nothing should be comming out of it
The problem I have with my LG dishwasher is that a green thick liquid leaks out onto the kick board. I noticed this when the door is half open, I wiped it off but it returns all the time.
Is this ooze perhaps similar to the same color as your liquid detergent or wetting agent (Jet Dri) ? A leaky dispenser would allow these fluids to leak down inside the door where they would continue down and out along the lower door edge. The only other option involves removing the outer door panel to investigate inside the door assembly. There should be no other sources of this sort of material.
Nov 01, 2016 | LG Dishwashers
Tool shop glue gun
that's just an unfortunate side effect of gravity. it happens to all glue guns. as the element heats the glue it turn into a liquid and oozes out of the nozzle. eventually it would stop when once all the glue in contact with the element has oozed out.
check this out.
https://www.youtube.com/watch?v=3H8ZgrOaxRc
Feb 27, 2014 | Tool Shop Dual Temperature Glue Gun 60...
Texas instruments ti 30x cracked screen
The liquid crystal of the LCD is probably oozing inside the calculator.
I don't believe it is worth fixing. It will probably cost a lot more than buying one of the newer Casios, TIs or Sharps.
Oct 02, 2013 | Office Equipment & Supplies
Where do i check the transmission fluid
Automatics have a dipstick level checker. Manuals do not. You check the level on manuals by unscrewing the fill plug along side of transaxle, about halfway up from the bottom. If no oil comes out, stick your finger in and feel for the level. The level should be right up to the fill plug. Add fluid till it just starts to ooze out.
Good luck.
Jan 28, 2012 | 2002 Pontiac Grand Am
Logitech c300 webcam,when I plug in usb,I get a blue screen and computer crashes
Open up your computer case and look at the motherboard (the thing everything connects into). Look at the little round metal topped cylinders on the motherboard and see if any of them are sort of puffy or oozing any liquid. It sounds to me like your motherboard is fried and that will cause it to crash when you plug in a USB device.
Mar 09, 2011 | Computers & Internet
I have a Samsung Silver Care front loader washing machine. When I turn it on water comes out the detergent dispenser drawer and a little oozes out of the main front door. Any ideas? Thanks, Kelly
Remove the dispensing tray (look for an under side spring clip or release) and check the fluid exit point--the machine washes the detergent into the drum along with other washing compounds. You may be better off using a liquid detergent rather than a powder. This may also fix the main door leakage too. Hope this helps!
Aug 15, 2010 | Samsung WF328AA Front Load Washer
How to check gear box oil level on suzuki swift 998cc 1998 model
Remove the rock guard then look for the filler plug. Remove the plug and using your small finger, feel the level of the fluid. The fluid should be even with the bottom of the plug hole. If the fluid starts to ooze out when you open the plug, the level is alright.
Aug 03, 2009 | 1998 Suzuki Swift
Black goo type liquid oozing from under dough hook when done.
Sounds to me like your seal is bad and you need a new bread pan, which includes the seal. Call phone no. in your manual to get the part you need.
Dec 06, 2008 | Sunbeam 5891 Bread Maker
Select Products SP33D Barnes Diaphragm Sump Pump 1/3 HP Logo
235 people viewed this question
Top Select Products Electrical Supplies Experts
Steve
Gene Haynes
Are you a Select Products Electrical Supply Expert? Answer questions, earn points and help others
