Question about HP ProBook 4530s A7K06UT Notebook PC - Intel Core i3-2350M 2.3GHz, 4GB
The digital mouse of my Laptop PC (hp pro portfolio 4630 s) does not work any more either deactivated please help me, I do not know how to activate it
Mouse whith cable when it's connected to the port usb work without probleme
  • HP Master
  • 7,627 Answers
Does it work on another machine, Yes/No? If no replace mouse. If yes reboot the machine without the mouse attached, when start up is complete insert mouse, does the machine respond?
Posted on Nov 18, 2012
SOURCE: HP Pavilion DV8000 Laptop USB problem
did you try reloading the BIOS drivers?
Posted on Apr 14, 2008
SOURCE: HP dv2000 USB mouse freeze when switching users without logging off
I have solved this problem.
Disable the HPQWMIEX.EXE service (either from msconfig or from services tab).
I had exactly the same problem - HP support didn't have a clue!!!!!
Posted on Jun 13, 2008
  • 44 Answers
SOURCE: MACBOOK PRO DAMAGED USB PORT
Hardware. Had a bad spill with a drop? Very unlikely you can have it fixed cheaply, but go to your local mac store and see if you can get it fixed.
Posted on Feb 04, 2009
  • 73 Answers
SOURCE: How to deactivate internal keyboard - Dell Inspiron 9400
if you go to the control panel, to hardware, in the keyboard section you should be able to uninstall the internal keyboards driver which will stop it working.
Posted on Mar 23, 2009
shahabdun
  • 249 Answers
SOURCE: I dont know whats wrong with my USB Ports
Reinstall USB 2.0 drivers.
Posted on Jul 19, 2009
Activate/deactivate touchpad
FN or function key and the icon key that looks like a mouse or touch pad. That combination will activate and also deactivate this mouse or touch pad feature.
Hope this helps ya.
Nerd Tech Junkie - Will
Dec 04, 2016 | Computers & Internet
My Advent 5421 Touchpad Is Not Working!!!
Advent laptop computers are equipped with a touchpad and two buttons that service the function of an external mouse. The touchpad can be turned on or deactivated, depending on the user's preference. It's not difficult to either activate or deactivate it.
Power up the computer. Connect a plug-and-play computer mouse to a free USB port on the laptop. The mouse is just temporary to help you get the touchpad working again. Locate the touchpad icon, which is in the lower right-hand side of the screen. The icon will appear as a gray square or rectangle, with two rectangular buttons underneath. Use the mouse to double-click on the touchpad icon, opening a window on your laptop screen. Inside the touchpad window, click the option labeled "Enable Device". Select other options for the touchpad, such as pointer speed and shape. Click "Apply", then "OK". Disconnect the mouse from the laptop.
Feb 02, 2013 | Advent Computers & Internet
Image pad light comes on ocassionally, lap top freezes, can not turn off. HP Envy Windows 7
Good Day,
For clarifications, is it that the computer freezes or the mouse pad doesn't work again while the keyboard still works?
Because for your type of laptop, around the top left corner of your mouse pad, there is a small hollow. If you double tap this place, you deactivate the mouse pad and if you repeat the tapping, you activate it. That's why the light there comes on and off. So may be you check it to know if you tap here during your typing.
I hope this helps you? Thank you for using Fizya!
Jul 23, 2012 | Computers & Internet
Laptop starts up but my cursor does not move
Hi, Maybe you deactivated it by mistake some laptop models have a button to activate and deactivate the mouse(touchpad) make sure yours is activated, if the problem is not that, then try re installing the touchpad drivers. You can find the drivers in the manufacturer home page. Take some time to rate me.
Aug 30, 2011 | Computers & Internet
I am having HP laptop. For last 2 days my touchpad
try reinstalling the driver for the mouse pad
that should go fine
Jan 05, 2010 | HP Compaq nc6220 Notebook
Touch pad doesn't work AT ALL!!!!
Hello there, Kasie!
Hopefully I can help. On laptops, there will *usually* be a "function button" one can press to disable the touchpad in the even that one wishes to use an actual mouse instead of the touchpad. -- This would be in the interest of not accidentally triggering clicks, or mouse movement when typing, etc.
Without knowing the make and model of your laptop, I can't tell you the precise button to press to re-activate your touchpad. On most laptops, you'll need to hold down the "Fn" key (usually at the bottom left or right of the keyboard) and then find the function key (top row of keys... F1, F2, F3, F4 and so-forth)... Look at your function key row. See if there is perhaps a key with a little "drawing on it" that looks like a touchpad.. like a horizontal rectangle with 2 smaller squares under the rectangle, representing the rectangular shape of the touchpad and the two "mouse buttons" beneath it... if you find something like this, it will likely be the one you'll need to press.
However, on some laptops, the button will be just above your touchpad... you'll be able to press it, and some sort of indicator light will either light up in red to let you know it's been deactivated, or white / green to let you know that it's currently activated.
One of my laptops which is an HP has the button at the top left corner of my touchpad.. I have to "double-tap" it to deactivate / reactivate the touchpad; while my Toshiba laptop has a button directly above the touchpad which I only have to press once. -- Both laptops have an indicator light as well. The HP's "double-tap button" will turn red / dark orange to let me know that I've deactivated it... With the Toshiba laptop, there is a light just below the touchpad area which is always lit up as a "bright white light bar" when active and simply not lit up when deactivated.
I wish you the best of luck with this, and hope I've helped you!
Apr 24, 2017 | Dell F3534 Touchpad
I have a few months old Toshiba Satellite M300
There is a button that activate and deactivate the keypad check if when you clean the keypad you touch a button by mistake that deactivate the mouse and click it again.
Aug 21, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
Fn key deactivation
You should find it in the BIOS, then just head to device configuration and you should be able to Enable/Disable it from there.
Dec 05, 2008 | HP Compaq Evo Notebook N410c
Cursor in laptop freezed
there are a few different ways that the touchpad can be deactivated especially if your notebook was pre-loaded with bulky management software.
First of all, most notebooks have a function shortcut for this. On mine it is function + F9. You should be able to see a picture on the keys that will describe this.
Secondly, as you did not specify which operating system you are using (or you did but it is in the hidden at the end of the details!), I will try and give a generic response:
- open control panel
- navigate to "mouse"
- open the "device settings" tab or similar
does this display anything about being deactivated? If it does, just activate it!
Nov 28, 2008 | Acer TravelMate 2300 Notebook
Mousepad not working
Hi Sharad arya,
Try pressing Fn+F8 to activate/deactivate touch Pad.
takecare.
May 12, 2008 | Lenovo 3000 Y410 Laptop
HP ProBook 4530s A7K06UT Notebook PC - Intel Core i3-2350M 2.3GHz, 4GB Logo
120 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
