PSU will not start once the plug has been removed & then replaced
I had to move a Dell PC. The supply woud not start when again pluged in. The light would flash & then quit.
Once I got ot going it did fine.
I decided it is a lot easier to buy a new power supply than to
go to all that fuss.
Posted on Jan 08, 2009
A712n light flashing on power supply
chk PSU and see if its on 110 or 208 maybe...might be showing bad power...or the MB isant happy...MY GUESS
Nov 13, 2012 | HP Pavilion a712n PC Desktop
All lights flashing rapidly
Indicators, Codes, and Messages
Dell PowerEdge 1800 Systems Installation and Troubleshooting Guide
Aug 06, 2012 | Dell PowerEdge 1800 Server
8400 dell hold power switch to get started
If it still acts up, compare wiring of the large motherboard Molex connector to the original. Dell used a variant that does not interchange. The enable wire is in a different location from standard ATX location.
If the processor is an AMD, remove cbattery and clear BIOS, and then try again.
Apr 07, 2012 | Dell Dimension 8400 power supply ** FREE...
My dell inspiration 910 has just played up. it was working perfectly before and i was using dell speakers and my ipod, ipod was removed, and left it still pluged in and charging and noticed the orange...
This sound as though the power supply adapter needs replacement.
If you can find a compatible power supply adapter perhaps you can charge you laptop.
A company call Batteries Plus may be able to help or Ebay may have you adapter power supply if you do a search.
You may also contact Dell for support on this issue.
Some Dell power supply fail due to overheating.
you may also want to check the power supply connector.
Apr 24, 2011 | Dell Inspiron Mini 10 Notebook
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
No panel lights, no fan, flashing front left light
the blinking lights means power issue. If you already plugged the computers power cable directly to the wall and stll get the blinking power light then your probably looking at a bad power supply in the computer.
Just for measures go into the system and if you have a video card remove it and start the system up. Also take out the memory stick and put them back in just incase during the move some components got loose. Put on your detective hat and check all connects. if problem still persist replace the power supply. In Computers terms thats called the PSU (power supply unit)
Your friend
May 29, 2010 | Dell Dimension 3000 PC Desktop
Dell 5100 will not turn on
Power "Outages" are not the problem, it is when it comes back on again,and the Power Switch is still ON, that's the problem, the "Inrush" current of reconnection, frequently "Blows" the Power Supply's, I suspect that is what has happened.. You probably need to replace your power Supply, simply open unit up, and remove PSU, via four screws at rear, and get a similar unit, they are relatively inexpensive, under $60.00 usually. Reinstall PSU and connect up all power plugs and you should be good to go.
Feb 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I put this tower in the corner for a few months, board lights up but no video (on board) when turning on, no signal message on monitor ,tried a pci video card and still nothing Worked fine prior to...
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Oct 12, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
My Dell 4700C PC will not start
Sounds like a blown power supply. Easily fixed. Go the a local computer store and buy a 400+ watt power supply, open your case, remove the 4 screws in the back, all the power plugs and replace with the new one.
Jan 08, 2008 | Dell Dimension 4700C PC Desktop
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
