Question about Canon Rebel XT / EOS 350D Digital Camera
Camera won't turn on
I have changed the battery. May be having problems from disconnecting from iphoto without choosing the "disconnect " button. What can I do?
  • 4 Answers
This happened to me today. The lens drive sounded weird - like off gear. Then it froze and wouldn't turn off without taking out the batteries. Then, it would turn on. Now it's ok. What I did was remove the cf card, lens, regular battery, and the little battery that is also in the battery compartment. I let it all sit while I did other things. When I put it all back together it turned on and I had to set the date but everything worked fine.
Posted on Oct 22, 2007
  • 883 Answers
Look for a small pinhole (possibly under the camera) and insert a pin with batts inserted to reset the camera
Posted on May 24, 2007
SOURCE:
Laptop black screen
You turned on your laptop and horrors upon horrors, the screen is BLACK! You see that the laptop has power but besides that nothing is happening.
I want you to know that there is a very good chance you can get out of this situation quickly and without any cost. This fix works on all brands of laptops:
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen.
After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
or if wont start
Here are the fix steps:
1. Turn off your computer
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer.
There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer.
Aug 08, 2013 | Computers & Internet
Will not power up
Hi, Please remove the Battery from the cameraand give a look inside the battery compartment. Use a spot light & makesure that place are clean , the battery connector pin are not bend , broken orrusted. After that insert the fully charged battery and try to turn on. If itsnot turn on then its confirm the camera internal power supply unit is faulty.For few reasons this problem started.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.2. Thepower supply transformer stops working & need to replacement.3. turnon button connection may disconnected.For the confirmation all you need to visit a camera repair store. Withoutvisual survey technician can't confirm you which one of them is faulty. Thankyou
Aug 04, 2012 | Vivitar ViviCam 8025 Digital Camera
My brand new camera will not turn on. Help?
Pleaseremove the Battery from the camera and give a look inside the batterycompartment. Use a spot light & make sure that place are clean, not rusted& the battery connector pin are not bend or broken. Use dry clean cotton orsoft cloth for cleaning the connector part. After that insert the fully chargedbattery and try to turn on. If its not turn on then its confirm the camerainternal power supply unit is faulty. For few reason this problem started.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.OR2. Thepower supply transformer stop working & need to replacement.OR3. turnon button connection may disconnected.
After visual checking by the technician is possible to say which part isfaulty.
For the confirmation you need to visit a camera repair store. Withoutvisual survey technician can't confirm you which one of them is faulty. As you said its your brand new camera so best solution is ask for replacement for the camera. Thankyou.
Jan 03, 2012 | Kodak EasyShare CX7330 Digital Camera
My nikon coolpix 5700 will not turn on, i have bought new battery for it and it just won't turn on. what do i do?
Pleaseremove the Battery from the camera and give a look inside the batterycompartment. Use a spot light & make sure that place are clean , not rusted& the battery connector pin are not bend or broken. After that insert thefully charged battery and try to turn on. If its not turn on then its confirmthe camera internal power supply unit is faulty. For few reason this problemstarted.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.OR2. Thepower supply transformer stop working & need to replacement.OR3. turnon button connection may disconnected.
For the confirmation you need to visit a camera repair store. With outvisual survey technician can't confirm you which one of them is faulty. Thankyou.
Dec 04, 2011 | Nikon Coolpix 5700 Digital Camera
My camera wont turn on.
This problem occurs when your camera has weak batteries or the wall outlet is not working. Try to change your batteries or just try another wall outlet for adapter/charger. Also, make sure that the battery is inserted properly.
You could also follow these steps:
Check batteries -> Connect camera to an AC adapter -> Remove all batteries -> Disconnect AC adapter -> Wait 2-3 minutes -> Reinsert batteries -> Reconnect adapter -> Turn on your camera.
I hope it works! Give it a try. If it won't work, contact the firm that produces your model of camera.
May 19, 2011 | Cameras
I have just downloaded the camera on to iphoto and have cleared the camera memory . I clicked the eject icon on iphoto and once cleared unplugged the USB download cable . I have just pushed the power...
Sounds like you did two things wrong...you deleted/erased/or formatted the camera using the computer. You disconnected the camera without using the "safely remove hardware" function.
Dec 12, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Lumix DMC-LX3 won´t turn off anymore (after pc connection)
Sounds like you didn't use the "safely remove hardware" function before disconnecting. If it won't turn off by itself, you need to remove the card and then the battery. Press all the buttons and leave it alone for 20 minutes...insert the card and then the battery and turn it on. This may work but you may have also have already corrupted the card and possibly the camera. While the card is out, you may want to try to download the pics using a separate card reader.
Mar 07, 2010 | Panasonic Lumix DMC-LX3 Digital Camera
Camera is not showing up on computer
try connecting and disconnecting a few times then blow on the battery hole and reinsert them
Oct 25, 2009 | Olympus FE-370 Digital Camera
Can't download large movie files to iphoto : (
i found the answer to my own question above and thought i'd share.
rather than iphoto, you can use "image capture," which is software that comes standard with the mac.
-Turn on your camera, and connect it to your computer with the cable that came with it.
-Close iPhoto if it opens automatically. Open Image Capture (Applications folder).
-Click Download Some to choose specific items to transfer, or click Download All to transfer all items.
If you click Download Some, choose the items to transfer, and click Download.
By default, Image Capture transfers still images to your Pictures folder, video files to your Movies folder, and music files to your Music folder. To choose another folder, choose Other from the Download To pop-up menu, then click Download Some or Download All.
Jul 20, 2008 | Canon PowerShot SD1000 Digital Camera
Video Format
If your computer has a SD card reader, you might be better off putting your memory card into your computer and just copying the data.
Have you made sure your iPhoto is up to date? Perhaps a new update caused this problem.. Maybe you should try an older version of the software. Also, you might want to try other software. (I think you are on a mac?), you might want to try the software that came with the camera, if it works on your computer.
May 05, 2008 | Canon PowerShot SD1000 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
