Question about Sewing Machines
Needle holder cannot be turn to the highest point
I unfortunately broke 2 needles. i successfully took the needles out and when i was about to put the 2 new needles- i cannot put it as the holder cannot be put in the highest place. I notices that one of the needles underneath ( where you thread the first thread) seems to be touching something underneath. the handwheel cannot be turned properly because of this and as a result cannot make the needle holder up . please help
  • shirley Nov 11, 2012
    Hi Sew Sew Jo, thanks for your info. I can't even insert the needle in the holder even if the screws are undone because the distance between the presser foot and the needle holder is too small not enough to squeeze the needle under and up the needle holder. the one holding the needle holder does not go high enough for me to insert it. my overlocker is a janome 8002dx. thanks for all your help guys.
  • Sewing Machines Master
  • 7,365 Answers
It's possible that when the needles were broken that the overlocker
either jumped time or damaged a part.
it would be a good idea to have the machine checked.
Posted on Nov 12, 2012
Testimonial: "Hi Debbie, i decided to call Janome to ask and they said that the loopers seems to be getting caught underneath. I will return the machine where i bought it and they can figure out. thanks for your help"
4 Suggested Answers
SOURCE: thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Posted on Mar 29, 2009
  • 52 Answers
SOURCE: Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
Posted on Jul 14, 2009
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
I have a Janome Memory Craft 4900. I broke a needle while sewing in a zipper. I replaced the needle,but now the machine makes a medal scraping noise when I sew. I took off the needle plate and bobbin...
did you find the tip of the needle? Also you may have a nick in the metal where the needle hit and broke.It can catch on other parts and need to be sanded or replaced.One time I had this issue and I found the tiny broken tip under my bobbin case.
Jan 18, 2014 | Janome Sewing Machines
Janome thread overlocker
check to see if the needle is turned the right way in the needle holder and that the needle is pushed all the way up into the needle holder..
May 29, 2013 | Sewing Machines
Machine stitches 2 0r 3 stitch then skips stitches on rest of seam
try changing the needle
Sewing machine skips stitches
needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Jun 01, 2012 | Janome 6019QC Mechanical Sewing Machine
Zigzag stitch problems on brothers pc-420 sewing machine
1.needle inserted incorrectly
round needle
Correct needle insertion is mandatory for proper use
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem
8.size of needle & thread & the fabric are not compatable
Mar 30, 2012 | Brother PC-420
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
How do you thread a pfaff 7570
If only we could put video links in here! But here goes:
Raise the presser foot;
Turn the hand wheel until the take-up lever (the hook bit that goes up and down, above the needle ) has reached its highest position;
Remove the small spool holder from the horizontal thread holder that is under the lid. Put thread reel onto spool, replace spool holder;
Pull thread behind first thread guide - it is the cream flat plastic bit towards the back - about 1" x 3/4" (i.e. the thread takes the first exit at the back);
Bring it down the left-hand long slot on the front of the machine, back up the right-hand slot, over the hook of the take-up lever, back down the right-hand slot and pass it from the side between the thread guide (silver metal bit just above the needle - looks a bit like curled metal). I found this last guide the most difficult to figure out - tried to get the thread into the curled bit - but you don't do that - it just slips in behind;
Thread goes through the eye of the needle. You can use the needle threader or not. Instructions for needle threader:
Lower sewing foot (makes more room and clamps the thread in the upper tension discs so it is less likely to keep spooling off while you are trying to thread);
Turn handwheel until the needle is in highest position;
Pull the needle threader straight down and then twist it to the front so the tiny hook on the threader goes through the eye of the needle;
Take thread under the larger metal hook on the left, put your thumb on it to stop it coming off, thread goes back towards the needle and under the small hook that is poking through the needle from the back;
Twist the needle threader towards the rear, releasing the thread carefully and allow the threader to move upwards. There should be a loop of thread left in the eye of the needle and you can now pull it all through to the back.
That sounds really complicated but I find the Pfaff needle threader works really well, unlike that of some other machines. I also have a Husqvarna Designer 1 whose needle threader works great, but the one on my friend's Designer SE is useless. Go figure!
Feb 02, 2010 | PfaFF Creative 7570
Bobbin holder won't stay put
If the bobbin case/holder is trying to lift up and the thread is staying partly around it, your bobbin case may have turned part way.
Remove the needle plate and the bobbin case. The outer edges of the bobbin case should be very smooth. I suspect you may see a needle hole in the flat area that was under the foot. If so, you will probably wish to take it to your dealer and show them. They may smooth it or recommend replacing it. When the bobbin case is placed back into the hook cup that it sets in, the retainer at the 11 o'clock position on it should only allow the case to lift up about 0.8 to 1mm at the most. If it will lift up more than this, press down firmly on the retainer and move it closer to the bobbin case. You must have enough room for the thread to pass between the retainer and the bobbin case, but too much clearance will allow the bobbin case to turn in the machine and it will be damaged by the needle.
Apr 09, 2009 | Husqvarna Viking 1
Bobbin holder
Make sure the needle is in the highest position before you try putting the bobbin holder in. The bobbin holder has a metal 'finger' which fits into a 'slot' in the housing and it only goes in if you have the needle up.
Mar 31, 2009 | Brother LS-2125 Mechanical Sewing Machine
Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Singer 7422 bobbin thread bunching up
I assume you checked to see there are no needle bits in the bobbin case holder.
Without looking at the machine it is difficult to diagnose the problem. It could be any one or a combination of problems, timing, needle bar height, damage to the hook and base etc.
I strongly suggest you have it looked at by a sewing machine tech.
Mar 29, 2008 | Singer 7422
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
