Question about Motorsports
Replace bt 50timing belt - Motorsports
Batteries for liniden d1788 battert # bt-1021
http://www.amazon.com/Replacement-Battery-BT-1008-BT-1016-BT-1021/dp/B00BM92AXS
Mar 11, 2015 | Lands Phones
Need a diagram for timing belt on a 1998 neon
Go to ( autozone.com ) and sign up for free and get access to parts, prices as well as service manuals with step bt step instruction for installing that belt.
Feb 21, 2014 | 1998 Plymouth Neon
ENGINE BELT OR CHAIN DOES THIS NEED TO BE REPLACED AFTER 100,000 MILES
Hello vance sundbe: My name is Roger and I will help you.For the PT Cruiser non turbo engine the recommended replacement is 102,000 miles. For the turbo engine the recommended replacement is 105,000 miles.These are Autodata specs. provided bt Gates belts. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Jan 26, 2011 | 2003 Chrysler PT Cruiser
Car mixes oil and water in the radiator.it snapped the timing belt and bend valves inlet and were replaced then orignal head gasket fitted bt problem continues.no mixing on dip stick
If it is still snapping the timing belt,then look for the cam hold downs to be torqued to tight,check lifters and followers for non movement,this would also cause the problem,when the timing belt is installed and ready,turn by hand the crankshaft multi revolutions to make sure there is no problems.
Sep 11, 2010 | Hyundai Accent Cars & Trucks
The tech at ryobi gave me the parts # 662329001, for my bt 3100. I only see the bt3000 for this #. Are they the same part?
Yes the BT3000 and the BT3100 use the same drive belts. Just be sure to order 2 as they must be replaced in pairs.
Apr 17, 2009 | Saws
Ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Mar 18, 2009 | Saws
NO Signal KV32fv26 Sony Trinitron
I think your problem is in tuner stage.
1. Check 32V dc available on BT connection on tuner.
2.If 32V available on BT,connect dc meter and put the unit on auto search and check the BT pin on tuner.The BT voltage will decrease and increase while it tunes.
3.If nothing stored after programming replace tuner.
Good luck
Dals123
Oct 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Small crack
k. i agree with steveepb on the sep 26th entry. bt i believe it is the engine cradle and yes it can be replaced i had a friend who had the same problem with a 2000 eclipse gs i think his replacement was roughly 150$ which thats with auto zone bt good luck sorry if this doesnt help.
Sep 25, 2008 | 2000 Mitsubishi Eclipse
Motorsports Logo
42 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
