Question about Haier XQJ50-31 Top Load Washer
Oil spots appearing on washing
When I put on a normal wash I'm getting oil spots on my clothes/fabrics. This is becoming heavier. I have cleaned out the filter and run the machine on empty with white vinegar to clean it out - there were still oil residue marks on the drum. What could be causing this and can I fix it?
  • 100 Answers
SOURCE: dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Posted on Jan 28, 2009
  • 7 Answers
SOURCE: washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Posted on Apr 10, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
SOURCE: Error code Unb: After the
I have had the same problem with the same model and rang up the help line to be told that the machine cannot sense the clothes in the drum. I tilted the machine forward and this worked for a while, sometimes i have to unplug at the wall so there is no electricity flowing through the machine for an hour and it resets itself,. Its not adequate but it works.
Posted on Jan 25, 2011
  • 215 Answers
SOURCE: hi,my haier washing machine is
Sounds like bearing and spider have gone, spider is the support on the drum which goes through the tub. then the wheel fits onto it. Open the door and see if you can lift the drum, if the drum lifts with a clunk or with ease then this will confirm the problem
Posted on Feb 25, 2011
Worth fixing dryer that is getting oil spots on clothes model mah5500bwq
This machine has no oil in the tub assembly. Over a period of time and using cold water washes body oil, dirt and undissolved detergents and fabric softener will accumulate at the water line on the inner wall of the outer tub. After the gunk builds up thick enough parts of it will break loose at times when using hot water and then get on the clothes.
Nov 03, 2012 | Maytag Washing Machines
My Frigidaire FTF530FS Front Load Washer appears to be leaking oil and it is getting on my clothes
Hello Loree Grudem - This can be the result of the shaft bearing and seal. They may have become worn and the transmission oil is creeping up to get in your water. Once this happens, it gets on your clothes to cause staining. Or possibly you have a buildup of fabric softener that comes loose and puts a greasy like substance in your water and on your clothing. Once you put your clothes in the dryer and the old fabric softener melts you will see these spots. I suggest contacting a professional to move forward accurately.
Oct 09, 2012 | Frigidaire FTF530FS Front Load Washer
Oil spots on clothes after washing
Yes, we had same thing with 20 yr old Maytag and the repair person said transmission. His advice, get a new machine. Transmissions are quite expensive and challenging to replace, approaching cost of a new machine to repair.
Feb 20, 2018 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Bosch wfk2801 yellow spots on washing
That sounds like oil but there's nowhere the oil would be coming from except the rear bearing but that would be more of a grey or black colour.Is your fabric softener yellow.it could be fabric softener.try not using any for a couple of loads & see.I don't know if the dots are washing off but fabric softener stains will normally wash off.oil won't.
Jun 04, 2010 | Washing Machines
Oil spots on clothing from washing machine - GE top loader
faulty clutch seal, Not a DIY
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Washing Machines
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Washing machine is dispersing oil on the clothing. We have taken it apart and cleaned it and have used the special cleaning solution because we thought it was dirty water being dispersed on the clothes...
Number 1 Cause .... using fabric softner in washer it accumilates around the top of the tub and it gets nasty! it depends on what type of machine you have if it is even possible to leak oil into the wash basket
Jul 05, 2009 | Kenmore Washing Machines
Oil Like Stains on Clothes
possibility is that the bearing seal is breaking down and oil from the bearings reaching the clothes. if so, the bearings will shortly follow. not an easy job and you are faced with a bill if i'm right
May 11, 2007 | Kenmore 45081 Front Load Washer / Dryer
Haier XQJ50-31 Top Load Washer Logo
16 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
