Question about HP vs17
No sound My dad had recently cleaned out my hard drive and in doing so i think the .inf and .icm files that are needed also got uninstalled, and I don't think I have the install CD anymore. Is there anyplace I can go to get those files, without having to pay for it?
  • HP Master
  • 19,396 Answers
You need to download drivers from computer manufacturer website, the drivers are free.
Fo example if computer (not monitor) is an HP, download from HP Support & Drivers .
Posted on Jan 05, 2009
Cannot rename hard drive
autorun.inf is a hidden system file. Make sure you can VIEW hidden files. Then look again at your portable drive's root folder.
(View TAB in your file explorer - Hidden Files checkbox)
Jan 28, 2014 | Toshiba Canvio 500 GB USB 3.0 Portable...
Tip
Windows Cannot Find "Copy.exe"
When i installed AVG Free last time it removed few virus including "copy.exe". so whenever i go to "My Computer" (win key + E) and double click on any hard drive then i find an error stating that (Windows cannot find "Copy.exe").
Solution:
Well the solution for this "copy.exe" conundrum is to get rid of a file called autorun.inf in each of the infected hard drives. here's the solution for the problem......
Make sure you or the virus scanner is run through the infected hard drives/flash drives. to make sure the virus files is gone.
Now, some forums said you could just select "Show Hidden Files" from the option and this would enable you to see "autorun.inf" file.
Also, some entries in the "autorun.inf"may be legitimate. so to check the file (even when you can't see the file) do this: Type in the infected hard drive label followed by autorun.inf for example f:\autorun.inf
This will load autorun.inf file in notepad.if the only entry is that incriminating copy.exe then this is what i did. i tried to overwrite the file with the same name autorun.inf. that din't work because autorun file was readonly. so i saved that blank file on the desktop and simply cut it and pasted it into the drive, then selecting the overwrite option. that should stop that annoying windows cannot find "copy.exe" message every time you double click into a drive. this will solve the problem!
Read more: http://comsguru.blogspot.com/2009/12/windows-cannot-find-copyexe.html#ixzz0nMpOFGpo
on May 08, 2010 | Computers & Internet
I downloaded drivers for dell E193FPp monitor. the only files in the download are 2 text docs, a setupinformation, ICC profile, and security catalog files. no .exe file. how do i install driver?
in most cases you will not need to install drivers for you monitor. These drivers are for windows XP and 2000 - so if you have a later version you should not need them.
For windows XP or 2000 you should have a readme file... if not then download the Dell drivers from
http://www.dell.com/support/drivers/us/en/19/driverdetails?driverid=r83276
Run the program and it should extract to a place on your hard drive, and once complete it should open the location with the following files
e193fp.cat, E193FP.ICM, E193FP.inf, Readme.txt and Version.txt
The Readme file gives you instructions on how to install for XP and 2000
Jan 08, 2014 | Computers & Internet
Our 2002 Gateway computer will not recognize a USB
Go to the following website listed below and download the file you need. It needs to be placed in the C:Windowsinf directory (not in any folder).
http://www.infdump.com/download-inf-file
Nov 15, 2009 | Western Digital WD Passport 250GB Portable...
I use a cruzer 4GB to go between my Mac & my work PC. Now, on windows, it says I have a possible worm virus. When connected to my Mac - there is no virus. Something to do with something called...
I believe that Windows is having an issue with the information in the autorun.inf file.
The entire sequence is initiated when the "disk change notifcation" polling discovers a new disk in the CD or DVD ROM drive. Then, if the "Auto insert notification" feature is enabled (it is by default), Windows checks in the new disk's root directory for the existence of an "autorun.inf" file. If found, Windows then reads and follows the specific instructions this file defines. If no autorun.inf file is found, then Windows refers to the new disk by its serial number and executes the default actions associated with the (data or audio) content on the disk.
My suggestion would be to delete the autorun.inf file as it is not needed.
Aug 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I downloaded a zip file to update my video driver, it contains e196fp.cat, e196fp.icm, and e196fp.inf, can you tell me where I should place these files in my hard drive?
Go into Windows Explorer. There is a folder under c: \Windows called Drivers where all the drivers are stored. You may have to change the file types, because it is a hidden file and will not show up normally. When you open up Explorer>Click on Tools>Folder Options>View Tab>little circle that you unclick to see hidden files. Just don't forget to click it back after you are done. Good luck.
Jan 04, 2009 | Dell E196FP 19" LCD Monitor
Couldn't open the hard Drive folders....
hi sir,
i think you have an autorun.inf file residing at your local drives. this probably infected by a virus.
go to control panel >folder option> click View> choose "Show Hidden Files and Folders" and uncheck Hide Protected Operating System Files, this will show hidden autorun.inf file. In your explorer, right click your local disk and click explore, this will show all your files and folders of your drive, navigate autorun.inf file, if found delete it.
note: it has an associated file called vbsscript file...if found also delete it..do the same with the other drives. empty recycle bin and restart.
Winsor
Sep 02, 2008 | Microsoft Windows Server Standard 2003 for...
Language
Hi-
Try uninstalling and reinstalling the driver and that should default it back to english. keep me posted for any progress and pls rate solution if it helps. Thanks!
Jul 16, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Generic Win982 drivers
kingstone 2 gb usb pen drive i can not work in win 98
Apr 23, 2008 | Computers & Internet
P223w lcd screen
right click on (.inf )file and click on install option.
Jan 12, 2008 | Gateway FPD2275W LCD Monitor
HP vs17 Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
