Question about Innova Equus 3130 C.A.N. OBD 2 Global Scan Tool IV3130
P1351 02/02 fault reading peugeot expert 2.0 hdi
Van becomes jerky as you drive
Can't find code to unlock radio/CD player on Peugeot expert hdi van 53 plate make of player is peugeot
53 plate Pug will not require a code - it uses car's VIN coded into radio internal memory. This can be done by anyone with lexia/proxia/Peugeot Planet diagnostic interface.
Feb 08, 2014 | Car Audio & Video
How do you turn off the airbag warning light on a peugeot parter hdi escapade 2003 88,000 miles
You will need to get the fault codes read first, a common problem is the wiring/connectors under the front seats. The fault code reading will help point you in the right direction. When the light is on the airbag will not work in an accident.
Jun 01, 2011 | Peugeot 405 Cars & Trucks
Peugeot partner van 2001 hdi broke down with em light..called aa.fault code read fuel pump at tank as was not pumping.pump replaced and em light came on straight away after driving.cleared code again still...
there is a valve on the back of the mechanical fuel pump under the bonnet
when the lift pump in the tank fails some tiny bits of the pump are sucked down the fuel line and clog up a tiny filter on the end of the valve that may be causing the light to come on amd possibly the engine to stall
i have found that the bosch kts670 will read just about anything you plug it in to
Nov 24, 2009 | 2005 Peugeot 405
I have a warning light on dashboard of peugeot 406 hdi and
sounds like a fault on traction control or abs
check the abs rings on the front drive shafts
Nov 10, 2009 | 2005 Peugeot 405
2005 peugeot expert 2.0 hdi turns off?
Sounds like a flakey connector - try hunting down all the connectors you can find under the bonnet. Separate them, spray with WD40 and reconnect. Start at the engine management computer (silver block with fins on and lots of wires coming out). Take great care not to bend pins.
Jun 08, 2009 | 2006 Peugeot 505
How do you remove the heater matrix on a peugeot expert
window wipers off remove trim and there is 10 mm nuts, remove them, remove speedo cluster and radio etc, there is 2 10mm bolts below each end in footwells at end bottom of dash, 1 bolt below your ash tray in front of gearstick, u got to get gear stick surround out.
Mar 30, 2009 | 2006 Peugeot 604
Peugeot expert 20 hdi
Hi, I have a 2.0HDI Expert which was doing the exact same thing as yours, blowing thick black smoke, sluggish and loss of power on gradients, a hissing sound and surging. I replaced the air flow meter but that didn't help. I was told to replace the turbo but a turbo expoert told me not to as it would blow white smoke if it was faulty. I was then told to replace the injectors but a diagnostic test showed them to be functioning fine. I was then told to look at the intercooler which had thick sludge at the lower left pipe. I replaced it today - Sunday 12th July and it is now driving like a new van. It now pulls me up gradients with ease in 4th and 5th instead of having to drop gear to get to the top. I got a replacement from Euro Car Parts for £147 inc VAT. To tell if this is your problem, look through the gaps in the lower section of the bumper at what looks like the radiator and look for sludge over the inside of the bumper and all over the pipe where it joins the back of the radiator (intercooler). Also open the bonnet and look down behind the grille for the same sludge. Hope this sorts it for you. Barry, Newtownards, Northern Ireland.
Jul 11, 2008 | 2006 Peugeot 604
Innova Equus 3130 C.A.N. OBD 2 Global Scan Tool IV3130 Logo
81 people viewed this question
Top Innova Measuring Tools & Sensors Experts
ray gallant
Vuk B
Tom Chichester
Are you an Innova Measuring Tool and Sensor Expert? Answer questions, earn points and help others
