I bought a slide scanner FS-C1-BX2 Digotaaal Film & Slide Convert
My computer dose not see it I do have USB 2.0 ports that it recemends.
Eddie
  • Anonymous Mar 23, 2014
    windows 7 driver
I called the dealer an the walked me through the problem.
Ed Crafton
Posted on Jan 07, 2009
I need a driver for the VuPoint Film and slide digital converter, Model FS-C1-VP-BX2. Would you be able to give me a link to that, I've not been able to find it. Thank you for your...
You can download the driver from:
http://www.vupointsolutions.com/downloads.php?d=drivers
Scroll to the bottom of the page to find the download link under "Converters" section.
The driver is in .zip format. So, after the download finishes, extract the driver file from the zip archive.
Hope this solves your problem. Thanks for using FixYa.
Feb 14, 2011 | VuPoint Solutions Digital Film Converter...
I have misplaced my manuel for Film and Slide Digital Converter model #fs-c1-vp-bx2. Can you help me?
You can download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Oct 27, 2010 | VuPoint DV-DV1-VP Camcorder
OVT Scanner won't run with Windows 7. Vupoint
We suffered this initially on a new laptop with Windows 7. I can't tell if the driver on the Vupoint website has been updated, or is the old XP/Vista driver, but we installed this (1/2011). In Picasa or the Photoimpressions software which comes with the scanner, we were then only able to acquire solid black images. However, when we tried all of the USB ports on the computer, we found that one of them (a USB2 rather than USB1 port) was able to function like normal. We suspect there is a funny issue with the amount of power going to the scanner from different USB ports, and maybe this interacts with the driver in some way.
Jul 07, 2010 | Office Equipment & Supplies
Vu point digital film/slide converter wont work when i plug the usb plug from the scanner into the computer a brief image appears across the screen aprox 3 secs (pic of scanner itself) then goes blank. I...
if this unit came from HSN (most did) then their specs show that it needs xp .. but their video claims it works for vista as well .. actually it depends on which model you have .. the FS-C1-VP . runs only on XP and below .. model FS-C1-Vp-BX2 .. has software to run on Vista and below .. Model FC-C520-VP-Bx2..runs on anything including vista and doesnt require software .. it just looks like a Mass Stroage Device when you plug it in .. these all look like a nice little machines for slides and negitives .. you might try unplugging the device .. reload the software (if you have any) ... then reattach the unit (to a different port) .. still problems then the USB port may be going into current limit .. you can try a different USB port (maybe one at the back of the computer) or better yet use a port expander with its own power supply .. make sure you dont have other USB devices that might be drawing current from the same USB source device (ok with the expander) .. if that doesnt get it going then if it came from HSN you can call their customer service number .. 800 933 2887 ... your item number would be 320-712 ... if the port expander or other suggestions fix it then let us know ..
it sounds like the unit is just drawing more current than your USB port can supply .. that happens a lot with large USB memory sticks (8gb or more) .. they are getting very close to or even exceeding the spec on the port .. some USB ports can do it others just shut down .. the external port expander with a power supply will almost always fix that problem and they dont cost much .. they are kind of nice also because you can put the expander ports within easy reach.
Dec 22, 2009 | VuPoint Cameras
How can I convert my 8mm tapes to a digital format and save to my hard drive?
If you have DVD Recorder then hook your Video-8 camera in analog AV input and burn a DVD, this will convert analog video/ audio signal of camcorder in digital format and transfer the data on DVD as well. Put that dvd in computer and save it in computer.
Nov 23, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Just installed a VuPoint Solutions Fs-C1-Vp Converter. When a slide or negative is inserted, a black screen shows up on the ''live view'' screen. When we transfer, a totally black image is saved on the...
how do you put a SD card into the vupoint slide converter
it has a white plastic thing preventing the SD card from going in and i cant pull it out
Jun 15, 2009 | Office Equipment & Supplies
Lost software CD
Download from the manufactures web site. They always post there drivers for there products there. And its free.
Jan 16, 2009 | Office Equipment & Supplies
Need adapter connectfor an HP Photo Smart 35 mm slide scanner
The HP Photo Smart 35 is a USB printer. Your computer has USB ports. You can utilize an open USB port on your computer to connect the printer. What is a CS100-818035 plug?
Jan 16, 2009 | HP Photosmart Photo Film Scanner (35 mm)
Not scanning
You have tried everything possible!. Try and reinstall the OS. If some dll files are corrupted, this will resolve it. You may have to reinstall all other software!
S. Mohan
Mar 09, 2008 | Canon CanoScan 8400F Film Scanner
93 people viewed this question
jasbo
jasbo
