Question about Toshiba REGZA 37RV530 LCD TV
Toshiba 37BV701B memory problem
I have to re-tune every time I switch on. described as a memory problem . Can it be fixed?
2 Suggested Answers
smokie999
SOURCE: Stand by light on my Toshiba 37BV701B is not working
Ihave same problem did you find out how to change the led
Posted on Dec 12, 2012
No sound
Try this:
http://www.wikihow.com/Resolve-No-Sound-on-Windows-Computer
or this:
http://www.thewindowsclub.com/no-sound-on-windows-8-7
Jan 25, 2014 | Toshiba 37BV701B 37 LED TV
Toshiba 37bv701b no sound
Try this:
or this: http://www.thewindowsclub.com/no-sound-on-windows-8-7
I require a manual
You can try here but these are not free:
http://office.manualsonline.com/manuals/mfg/toshiba/toshiba_laptop_product_list.html
I get mine from retrovo.com
Start here: http://www.retrevo.com/samples/Toshiba-Laptop-manuals.html
Dec 28, 2013 | Toshiba 37BV701B 37 LED TV
Oct 21, 2012 | Toshiba 37BV701B 37 LED TV
Technika flat screen tv forgets digital channels found if switched to standby
Channel memory of stored channels is contained in a Eprom which may be part of the microprocessor------voltage when set is shut off is often from either the standby supply or even a filter cap that holds sufficient charge to maintain voltage for the memory.
Look in those areas first.
An alternate way would be to go to a box and input signal to rear audio and video jacks---the box would then retain channel memory etc and this would bypass your issue.
Apr 17, 2012 | Televison & Video
How do i get my toshiba regza lcd tv to work via the antenna/cable input
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
Jan 08, 2011 | Toshiba Televison & Video
Toshiba A135-S4527 cmos battery dead
I found where the cmos battery is located. By the Toshiba tech support website , it's next to the PCMCIA Slot, just behind it. To get to it, Take off LCD, keyboard, top palmrest, hard drive, battery, memory, top power cover,switch board, modem, network. and some others. Too many to describe here. Items to remove not in order.
I Have the service manual downloaded already.
Let me Know
comier957
Aug 07, 2008 | Toshiba Satellite A135-S4527 Notebook
Sharp cd-c472
I did solve the problem; instead of spending time online looking for a user's book, I tore my house apart and found the original one. Thank you for your response.
To set the clock for the Sharp CD-C472:
1. Power switch off
2. Press CLOCK button.
3. Within 3 seconds, press MEMORY/SET button.
4. Press TUNING/TIME to select time mode (12 or 24 hour)
5. Press MEMORY/SET button.
6. Press TUNING/TIME to select hour.
7. Press MEMORY/SET button.
8. Press TUNING/TIME to adjust minutes.
9. Press MEMORY/SET button.
Please note, your "solution is valid for" choice forced the Sharp CD-C401 selection BUT THAT IS NOT ACCURATE THIS SOLUTION IS SPECIFIC TO THE CD-C472.
Jun 30, 2008 | Sharp CD-C401 Shelf System
MyFi loses proper index to recorded music
Sometimes this will fix itself if you take the battery out. Otherwise, the best way seems to be to empty the memory, and start all over, recording on a blank slate. These are really pretty awful machines, with endless problems.
The on/off switch on mine just broke, and I say "good riddance."
Feb 03, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Toshiba tp50f60
1. Check the TV's horizontal and vertical hold. 2. If there is a VCR connected: Shut off the VCR. If the problem clears up, the VCR is not properly ?fine-tuned.? Turn the VCR on and troubleshoot the VCR problems. 3. If a converter is connected to your TV and VCR: The VCR needs to be on channel 4. VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. 4. Check the fine-tuning of your TV. good luck :-)
Jan 11, 2006 | Toshiba TP50G60 50" Rear Projection...
Toshiba REGZA 37RV530 LCD TV Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
