Question about Motorola Mobility RAZR V3
Screen out side
Hello, i got a razr v3. every time i ihave my phone opened it shows the M(morola logo. but when i close it, it stills shows the M, when it should say the time, ect. do u think its the whole screen?? or is it programing? thanks
    Scholar:
  • 91 Answers
It's actually the magnet sensore inside the phone. This can be fixed by putting another magnet from a razor on the top left corner of the phone underneith the battery, then you will need another one to place under the faceplate right on top of the other magnet. Simply changing the magnet sometimes works but not every time.
Posted on May 28, 2007
I hope this anser helps you: First, Press the center select key to open the menu, then scroll to SETTINGS & TOOLS and then go to Display Settings, and press the center select key to select it, nou you should go to "Clock Format" and press the menu key. Scroll to Front Clock (for the external display) and press the center select key THAT IS!
Posted on May 26, 2007
How to Upgrade Motorola RAZR V3
well ,that means that the ribbon cable that flexs when you open and close the screen is bad,, could be the screen tho..you need to let me know if the phone still works,does the keyboard light come on..
Mar 12, 2012 | Motorola Mobility RAZR V3
I have a Moterolla V3,my LCD screen is not displaying correctly, I see white and red, but I can't make out anything else. When the phone initially turns on the screen displays the Verizon perfect...then it...
The flex that connects your screen to the phone board is bad and has worn out. It is commom with flip phones. All you need do is to replace the flex and be very mindful of how you close the flip phone.
Take care.
Nov 16, 2009 | Motorola Mobility RAZR V3
Morola v3 battery don't work properly...
no not in the moto razr.....what its sounds like is a fault between the main board and the lcd flip top........open the back panel by removing the battery back and battery and the screws. It will just pop off now. Make sure that when u put it bck together the ribbon cable from the lcd panel is firmly secured to the board. TRy it again GOOD LUCK
Oct 07, 2009 | Motorola Mobility RAZR V3
When i close my motorola V3 it think'S it'S opened
two thing s to correct this problem is to change the flex cable for the screen problem or reflash the firmware on the phone.
Dec 16, 2007 | Motorola Mobility RAZR V3
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
My Razr doesn't know that it's closed
There is a little magnet in the inner half of the flip, below the screen. it is on the right side if you are looking at the phone as you would normally use it. I hope you kept the old housing...
Oct 10, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
141 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
