Xirrus XN4 forgot password
Hello, please help me! I forgot password of Xirrus Wi-FI Array XN4. How can I reset to factory default? Thanks!!!
To reset a Xirrus Array to factory default:
Connect to the console with Putty via Serial - Setting the Baud to 115200.
Power cycle the Array and watch the boot sequence very carefully. Press Spacebar access bootloader
Use the default UN/PW: admin/admin
- You should be at an XLB> prompt
-Type 'env reset' and press enter
Array will reboot and all settings should be back to factory default.
Posted on May 02, 2013
  • Mitch Nikolov
    Mitch Nikolov Sep 15, 2015
    after typing env reset and it has finished. You will need to type "boot"
    if anybody gets stuck :)
  • 7,627 Answers
Look at the back of the device for a tiny recessed button, sometimes red, not always, PUSH and hold until you see the lights go out or change, usually 10 seconds or so. This should reset your device to default settings. You will have to reconfigure your SSID and security settings of course.
Posted on Nov 09, 2012
  • John Porter
    John Porter Jun 26, 2014
    The xirus is not a cheap soho router with a reset button. It's an enterprise device. I'm shocked you're marked down as an expert and give this reply.
  • Mitch Nikolov
    No reset hole or button mate. Have to do it through the console.
kakee
  • 1269 Answers
SOURCE: asking me for wi-fi password
The wifi password is the same as wireless network key (either WPA or WEP key). That's the same password that you used when you tried to connect to the wireless network using your laptop.
Posted on Apr 27, 2009
SOURCE: i can not remember my wi-fi password. i need it to
If you have tried the default passwords (blank, admin or sysAdmin) and they don't work, you will need to reset it back to factory settings. You can do this by finding a hole at the back of the unit and pressing the hidden switch there for a few seconds. After that it should be back to its original configuration. You will obviously have lost any changes you made to it since you took it out of the box.
Posted on Jul 02, 2009
nyilasrobert
  • 627 Answers
SOURCE: how to reset Edimax BR-6204Wg router? default wireless password?
push reset button at least 10 seconds
Posted on Jul 10, 2009
dante777
  • 623 Answers
SOURCE: i forgot my password for my router
Yes, you can (and you have to ) reset your router to factory default if you forgot your password.
Here is how to do it:
  1. Use a pointed object to press and hold the Reset button on the back of the base station.
  2. When the Power light on the front begins to blink green and orange, release the Reset button. The Power light turns solid orange. When it it turns solid green, the restoration is complete. This process takes about a minute.
Note that your current settings are erased and the base station is restored to the factory default settings!
Now you should be able to connect to the router.
  1. You can access the base station at http://192.168.2.1
  2. The default password is "admin"
Look at this article and check how to upgrade the firmware to the latest version. (I read about lots of problems with old firmware.)
You should have a manual.If you don't, you can get it here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jul 12, 2009
govinda123
  • 2260 Answers
SOURCE: how do i unlock my wi fi
Is there any computer online using the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Posted on Jan 26, 2010
I forgot my router password so i want to know what can i do to reset it
You will have to reset the router to factory defaults
BEWARE - this means you will lose all the router settings and will have to set them up again including the ADSL settings which your internet provider should be able to help you with. Then when you setup wi fi security all the computers will need the encryption key and sddi broadcast name changed to match
To reset to default settings, turn off the device first. Hold the Reset button and then turn on the device; wait for 5-8 seconds and then release the button. Reset device's configuration to factory default.
http://setuprouter.com/router/trendchip/hg520/manual-1089.pdf
(the default username/password is admin/admin)
you will need a direct connection ethernet cable between a computer and the router as the wi fi will be not set up after the reset.
Sep 28, 2016 | Huawei HG520 ADSL Wifi Router
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
If I get a default password must I change my other devises which obviously use another password?
depends. If you are referring to the admin function of the router then the password to it is only needed to change the router settings.
If you change the Wi-Fi encyrption key on WPA or WEP key via the admin function then any computer using Wi Fi would need to match the WPA key or WEP key to access the wi fi.
If the default password does not work the router may be able to be reset to factory settings if you do not know password which requires you to set everything up again in the router and is not easy to set up unless you know the isp settings and network settings.
Dec 31, 2015 | Computers & Internet
Forgot wi-fi password
if you have access to the wi-fi router, you can reset it to default password by pressing reset button on the router, this will revert it back to the factory settings, including router name and password, the password will be on the router itself.
Nov 07, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
When I use Xirrus wi-fi inspector it says no adapters avaiable and can't see SSID
I had the same problem, then i realized that the soft itself must be used in a laptop with WIRELESS adapter, NOT in a desktop pc with a ethernet adapter.
Jul 16, 2011 | Trendware TEW-671BR Router
Where username and passward please help me.i want wi .fi
if you forgot your password, you will have to reset your modem back to factory defaults. With the router on, press the reset button down with a paper clip for 10 seconds..router will reboot, let it go through this for 30 seconds. Then access web frontend menu at 198.168.0.1 user is admin and just leave password blank. you will have to set a new password and set all the security
Jun 15, 2011 | D-Link DIR-615 Wireless Router
Hi am having prob on setting my WI-FI i forgot the WI-FI/WPA Key
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 05, 2011 | Computers & Internet
Slow wireless network issue
Check for Rogue Wireless devices in your area. Another Wireless device running the same frequency will cause trouble on both yours and theirs.
ONLY use channels 1, 6 and 11.
You can get a free Wi-Fi scanner from Xirrus.com
Dec 08, 2010 | HP ProCurve Radio Port 210 (J9004A)...
Im putting in the right password but its telling me ther is an errer marymary19822live.com
  • If your problem is at the entry page for the router:
If you reset the router it comes to the default settings. This means that it come to the default password too. Clarify me the brand / model to post you back the factory password.
  • If your problem is at the Wi-Fi password:
Log-in at the settings for the router page and locate the Wi-Fi (or Wireless) section. At this section there is a security section. Here you can locate the Wi-Fi password.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 03, 2010 | Computers & Internet
Open Questions:
Computers & Internet Logo
4,724 people viewed this question
David Payne
David Payne
