Question about Pool & Spa
My 2 hp, two speed hot tub pump works in low speed fine to circulate but when i try to start high speed it makes a noise and the pump shuts down i took the pump to electrian and they said pump was fine i am puzzled
  • dan o Nov 10, 2012
    Thank you john i believe you are correct I had a hot tub repair man here he tested board and flow switch all was ok his answer was motor also .
  • 3 Answers
SOURCE: hot tub pump will not
This can be one of three issues.
1.  Starting capacitor as you have suggested.  You can take the capacitor to a motor shop and have it tested or test it yourself if you have a meter that will check capacitance. 2.  Low/High voltage.  If the voltage is not at the proper levels (10% up or down) then the unit may have a hard time starting. 3.  Something might be binding up the impeller.  Disconnect the power and carefully check to see if the shaft of the motor spins freely. 4.  A short in the windings.  If none of these seem to be the problem, then you will probably need to replace the motor.
Posted on Jan 12, 2009
SOURCE: Pump will not work in high speed
Clean the relay contacts on the board. Cut the power, ofcourse. Also, try switching the hot wire on the low side of the pump to the high side to rule out the pump.
Posted on Jun 08, 2009
john224
  • 1378 Answers
SOURCE: pump stops running on high speed
You have a magnetek motor and it is overheating and cycling its thermal overload. A local electric motor repair shop may be able to fix it however it will likely need to be replaced. It is to costly to repair the motor if the damage is in the windings.
Assuming at that low a horsepower it is 115V, the likely replacement motor is a catalog #BN37. We sell it for $157. You are usually better off replacing the seal when you replace the motor and most Jacuzzi pumps are either a 200 or 1000. They should be around $5.
Posted on Jun 12, 2009
muralme
  • 20 Answers
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Posted on Jul 12, 2009
  • 990 Answers
SOURCE: Motor is hooked up correctly according to
You have 220v running into your motor, the red and the plack are in most cases the same 110v line and what your calling a white netural is a common line. In other words the second half of your 220v line. If your red and black are the two opposing 110v lines that make up your 220v and they are put on the motor and turned on they short aginst each other and blow the breaker. One of your 220v lines should come into your hi -low switch and then split to your high and low on the pump. The other half of your 220v line will go to the common or what your calling nuteral. The difference is a netural completes a 110v circut and a common completes the 220v circut it will take to run the motor. One of the splits will complete the low speed circut and the other will complete the high speed circut. You need to check your voltage comming into the spa, the way the spa is wired (110v-220v), and how the motor is wired (110v-220v). For your spa this will be in your owners manuel or on a scematic inside a panel or door and is quite often a plug you change from one spot to another. On your motor will have a scematic on the back of the motor that will tell you haw to adjust the wireing already in place on the wire board of the motor. This may sound deep but if all your voltages are set the same and your high and low are the same leg of power, this should fix your problem.
Posted on Oct 31, 2009
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
3 hp hot tub motor Sta-Rite tub has two speed low for filtering and high for jets low starts and then stops high speed works fine
make sure you make a wiring diagram or just unplug the plug from the mother board and search your area for your local pool pump repair guy with free testing. these are a high $$$ motor and not a good one to practice on, save it for a pro ! it might just be a dirty switch or need to be reset I don't charge any thing for that, and while your there ask him how to take better care of your $$$ pump ?
jay the pool pump repair guy longwood Florida
Sep 05, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
Hot tub pump flo-master hp suddenly wont start. it' one year old and was working perfectly. air side started to make a squealing noise the night before. draining hot tub to check volute to make sure motor...
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
My 2 speed jandy pool pump is over heating
you may either have a bad start/run capacitor for the high speed side or bad supply voltage feeding the high speed side. If there are no loud bearing noises, it should just be either of those two problems.
Aug 15, 2009 | Jandy PlusHP Pool Pump EE Dual Speed - 2.0...
Jacuzzi hot tub will not shut off
I take it for granted that you know when the tub is in cycle mode for water circulation, ( the tub will do this every 4 to 8 hours unless programed otherwise). If it is truly going into the low speed on the pump, the problem lies in the circuit board. The double click you hear is the relay for the pump turning off and then on again. This is a costly problem to diagnose as circuit boards start at 200.00 and go up. If it is the relay, the only way to replace one is to replace the circuit board.
Jul 03, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Installed new 2 speed motor olny low works
IF the filter is clean, then your problem is electrical. First make sure you are not using an extenesion cord. These pumps do not work well with a cord over 6ft long. Then make sure that the pump is on a dedicated outlet. No Microwaves, computers competing for power. Most likely the pump is not able to draw enough power and is shutting off.
May 30, 2009 | Waterway 1 Hp 115 Volt 2 Speed Side...
My LG washer, model wm2277hw gives me the OE on the display. I have cleaned out all the possible areas where it could be clogged around the pump, but still makes a bad noise when it gets to the rinse...
You may have a broken pump impeller - you will have to order the whole pump (the filter on this machine allows BIG stuff through and it can ultimately damage the impeller)
Have you run this through diagnostics and determined if it is the drain or recirculating pump?
To run diagnostics:
Press and hold the "Spin Speed" and "Soil Level" buttons at the same time - then hit the power on the button
All lights should display - Press the Start Pause button throught the following cycles:
1 - Tumble clockwise
2 - Low speed spin
3 - High speed spin
4 - Prewash inlet (let it run for a few seconds to put some water in the tub)
5 - Wash Inlet
6 - Hot Water inlet
7 - Bleach inlet
8 - tumble counter clockwise
9 - Heater
10 - Circulation pump (see if your noise occurs here)
11- Drain pump (let this run until the tub is empty)
12 - Power off, finished
Once you figure out which pump, order the correct replacelement
Apr 27, 2009 | LG WM-2277HW Front Load Washer
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
Pool & Spa Logo
833 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
